anyone did propeller validation before?
Old   October 8, 2007, 01:41
Default anyone did propeller validation before?
new to Fluent
I have never done anything related to propeller before. Please kindly give me information based on your experience.
Goal: Validate an experimental data of propeller in hover condition.
Known: thrust, RPM, Power
Method used: Momentum theory using Fan BC in Fluent.
What I have done: Calculate the pressure jump and set it in the fan BC. Use pressure inlet, fan, pressure outlet BC with 0 Pa total gauge pressure at inlet and 0 Pa static gauge pressure at outlet.
Where I am now? I got m dot (mass flow) which is 2 times of what I should have.
Help......
Old   October 8, 2007, 18:13
Default Re: anyone did propeller validation before?
red lemon
There are some public domain results for Navy Propellors. Can use mixing plane or sliding mesh (rotating). Here's one : http://www.fluent.com/about/news/new...1/pdfs/s10.pdf
Old   October 8, 2007, 21:56
new to Fluent
Thanks red lemon,
I want to try using actuator disc, because it is likely that the propeller will be changed later.
any info about this?
I search the forum and find some discussion about it. I tried what they suggested, however the results is not good.
to assume that the outlet static pressure is equal to atmosphere, how far should I put the domain distance from the disc?
Thanks
Old   October 10, 2007, 18:04
red lemon
difficult to say but up and downstream distances of 5 and 15 diameters seems ok. Outlet static pressure = rho*g*h for hydrostatic submersed pressure - ensure bc is far enough away from prop.
Propeller calculation toil CFX 15 May 22, 2017 04:06
Propeller Validation Case nomad STAR-CCM+ 2 February 14, 2012 21:05
Propeller Validation nomad CFX 0 May 20, 2011 13:02
Modelling a propeller tomg STAR-CCM+ 4 April 28, 2011 17:22
a propeller 2 way fsi kantored CFX 9 April 11, 2007 14:51
