Scheme scripting for transient flow
Old   October 26, 2007, 11:24
Default Scheme scripting for transient flow
john deas
Hi, I found that
(iterate x) allows me to compute x iterations. How can I advance in time to do something like
(dual-time-iterate 1 10) for example ?
thanks,
JD
Old   October 26, 2007, 11:40
Default Re: Scheme scripting for transient flow
john deas
Answer is simple: I can mix tui and scheme commands in a journal file.
sorry for your attention
Old   October 29, 2007, 05:24
John Deas
In fact my problem remain: I can not include journal command inside a scheme loop, like in:
(define (doit x x-max dx)
(if (<= x x-max)
(begin
solve/dual-time-iterate 1 2
(doit (+ x dx) x-max dx)
) ) (doit 1 10 1)
So if anyone as an idea about it it would be much appreciated.
thanks
Old   October 29, 2007, 19:20
Javier Larrondo
Use... (ti-menu-load-string "solve/dual-time-iterate 1 2")
Also if you have variables like a=1 and b=2 you can use
(ti-menu-load-string (format #f "solve/dual-time-iterate ~d ~d" a b))
the last one is very useful when you integrate scheme and tui.
Cheers,
Javier
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 05:21
Compressible flow, no data at the outlet mireis FLUENT 6 September 3, 2015 02:10
Scheme file for sinusoidal channel flow elobb FLUENT 0 November 24, 2009 10:27
2D scheme for two-phase flow is needed Oleg Main CFD Forum 3 June 19, 2002 10:31
mass flow inlet Denis Tschumperle FLUENT 7 August 9, 2000 02:19
