October 26, 2007, 11:24 |
Scheme scripting for transient flow
Hi, I found that
(iterate x) allows me to compute x iterations. How can I advance in time to do something like (dual-time-iterate 1 10) for example ? thanks, JD |
October 26, 2007, 11:40 |
Re: Scheme scripting for transient flow
Answer is simple: I can mix tui and scheme commands in a journal file.
sorry for your attention |
October 29, 2007, 05:24 |
In fact my problem remain: I can not include journal command inside a scheme loop, like in:
(define (doit x x-max dx) (if (<= x x-max) (begin solve/dual-time-iterate 1 2 (doit (+ x dx) x-max dx) ) ) ) (doit 1 10 1) So if anyone as an idea about it it would be much appreciated. thanks |
October 29, 2007, 19:20 |
Use... (ti-menu-load-string "solve/dual-time-iterate 1 2")
Also if you have variables like a=1 and b=2 you can use (ti-menu-load-string (format #f "solve/dual-time-iterate ~d ~d" a b)) the last one is very useful when you integrate scheme and tui. Cheers, Javier |
Compressible flow, no data at the outlet | mireis | FLUENT | 6 | September 3, 2015 02:10 |
Scheme file for sinusoidal channel flow | elobb | FLUENT | 0 | November 24, 2009 10:27 |
2D scheme for two-phase flow is needed | Oleg | Main CFD Forum | 3 | June 19, 2002 10:31 |
mass flow inlet | Denis Tschumperle | FLUENT | 7 | August 9, 2000 02:19 |
