Free Jets
Old   November 4, 2007, 15:23
Default Free Jets
Valerio
What are the best boundary conditions type on simulating free jets???
Old   November 5, 2007, 11:40
Default Re: Free Jets
Valerio
i'm trying with simmetry on all domain boundaries...is it right???
Old   November 7, 2007, 03:39
Adrian Lai
I've tried a single free water jet into a stagnant water body, do u mean this by 'free jet'?
Adrian
Old   November 7, 2007, 10:32
Valerio
yes. Free Jets for jets in the same fluid (ex: water in water) instead free sufarce for jets in different fluids (for example water in air). Actually i'm trying the simulation in a cavity with walls sufficiently far from fluid inlet. In other words i'm trying on reproducing real conditions.
Old   November 7, 2007, 10:39
Adrian Lai
Pressure outlet boundary condition at the outlet; Wall boundary condition would be okay if the jet is sufficiently far away from the boundaries; velocity inlet at the jet nozzle.
Finer mesh required near the jet.
Right now I need to run it as unsteady case (til it becomes quesi-steady), not sure whether anyone has done it using steady calculation with success.
Adrian
Old   November 8, 2007, 11:01
Valerio
I know! However i already studied flow field inside another device and now i'm using calculation at outlet like new problem's boundary conditions for external field simulation. Flow field is not very easy...i have not a classic submerged jet but 3d swirling jet. To peform a complete simulation of internal flow and external jet in unsteady state is not very very easy because inside the device the flow is compressible but the highly deceleration conduce the fluid at outlet at incompressible velocities so that i can simplify my simulation. And i will be (with a complete simulation) a too much big domain.
Old   November 8, 2007, 11:04
Valerio
i have another question...
in unsteady state simulation i would to obtain a graphic of pressure versus position along a particular line in time.
is it possible define a fixed scale in XY plot, in same way???
Old   April 8, 2010, 15:14
Default Re no. relation for Jet
ahasan1 is on a distinguished road
I think this is the best place where I can ask my question. I am wondering what is range for Reynolds number (Re) for a single jet. That means laminar single jet flow is condition up to what 'Re' number. From which 'Re' number, turbulent flow condition starts. Also, when is incompressible flow valid for single jet?
ahasan1 is offline   Reply With Quote
CFD beginner:- Help needed, general questions on Free jets? (Fluent 5.2.3) Wong, R.Y.T. Main CFD Forum 5 October 22, 2010 00:51
Can Flow-3D plot the free surface area in Iso-surface or colour variable? therockyy FLOW-3D 1 June 20, 2010 19:36
CFX 4.4 New free surface option Viatcheslav Anissimov CFX 0 April 3, 2002 06:27
Summer Course on ''Jets in Cross-Flow'' alfredo soldati Main CFD Forum 1 May 5, 2001 21:34
Variable Density - Free Surface with FIDAP Vitaliy Pavlyk FLUENT 7 May 2, 2000 15:56
