November 8, 2007, 00:57 |
Water level at outlet(VOF)
hi, i'm doing a free surface simulation in which i need to keep water at a desired height at the outlet What bc shall i use and what parameters shall i specify??
November 8, 2007, 04:35 |
Re: Water level at outlet(VOF)
Hi, if you need to keep the water at a desired heigth at the outlet, you can use the VOF model with the option "open channel". At the outlet, a "pressure outlet" with the open channel option will work. hope that helps
November 12, 2007, 00:40 |
ThANKS the reply.. i'm using fluent 6.1.22 Where do i select this option of open channel??
November 12, 2007, 06:06 |
Go to Define>Model>Multiphase>VOF there you will get this option... for Open channel flow..!
November 12, 2007, 13:46 |
there is no such function for 6.1. only 6.3 has
November 12, 2007, 23:48 |
So whats the remedy in fluent 6.1.2
[snappyHexMesh] Boundary layer in a pipe | Clementhuon | OpenFOAM Meshing & Mesh Conversion | 6 | March 12, 2012 12:41 |
height of water level in two-phase flows? | Michael Bo | CFX | 2 | August 23, 2004 01:50 |
Terrible Mistake In Fluid Dynamics History | Abhi | Main CFD Forum | 12 | July 8, 2002 09:11 |
uptodate water distribution network | fredius,magige,tanzanian,(e.a) | Main CFD Forum | 0 | January 27, 2002 07:10 |
