December 3, 2007, 01:08 |
Drag, Lift and momentum plots
Hi Any one can tellme how to plot drag, lift and moment coeefficients vs for differnt postion of the airfoil along the wall in Fluent. I am having the convergence history file for Cd, Cl and Cm. I got Cp VS postion but i am not getting the option for the above mentiond problem
December 3, 2007, 03:20 |
Re: Drag, Lift and momentum plots
You should use a UDF (in Define) to get that but I'm not sure about the formula you have to use (If you find it, I will be glad to see how it looks like ). (It is possible to use the node values for the pressure and for the force).
Lift coefficient in Eulerian multiphase model | hennas | FLUENT | 1 | July 4, 2011 16:50 |
Lift, drag and momentum coeff??? | inginer | OpenFOAM | 1 | December 7, 2010 11:42 |
Lift & Turbulent Dispersion in Stirred Tank | ozgur | FLUENT | 0 | April 23, 2007 10:01 |
Help:lift and drag | Yap Wen Jiun | Main CFD Forum | 5 | April 2, 2000 17:13 |
aerofoil lift and drag curves (with automatic excecution) | Elizabeth | FLUENT | 0 | February 26, 2000 11:47 |
