Annular inlet profile of experimental velocity
Old   December 7, 2007, 10:05
Default Annular inlet profile of experimental velocity
fluid
Hi, i'd like to define an inlet velocity profile, based on experimental measurements, on an annular inlet surface. On a section of the annulus the velocity data resemble a profile like 2 parabolae at a certain distance. This profile has to be rotate by 360° to form an axisymmetric surface over the annulus surface. Clear? Thanks, fluid
Fully developed 3d velocity profile: Square inlet! Taru FLUENT 6 September 14, 2015 08:38
[swak4Foam] Scale discrete inlet velocity profile with groovyBC cboss OpenFOAM Community Contributions 1 June 20, 2010 13:02
Specify Inlet Velocity Profile JHardes ANSYS 1 March 17, 2010 13:59
How to create Hemisphere Velocity Profile at inlet Nelson FLUENT 0 July 10, 2005 21:44
using profile to specify inlet VOF and velocity yf FLUENT 8 June 2, 2005 05:40
