December 15, 2007, 06:07 |
parallel
Hi I want to setup parallel fluent in windows . 1-workgroup or domain is better? 2-Do you have any document about setup parallel fluent? I setup it in domain network with rshd but I have some problem when I run it. 3-rshd or mpich ? please help me thanks
January 10, 2008, 11:38 |
Re: parallel
Domain would be good. I would recommend the usage of HP-MPI with the newest version of FLUENT6.4. If you want to use FLUENT6.3.26, you may use MPICH2, with installation MPICH2 packages downloaded from the FLUENT website.
Script to Run Parallel Jobs in Rocks Cluster | asaha | OpenFOAM Running, Solving & CFD | 12 | July 4, 2012 22:51 |
parallel performance on BX900 | uzawa | OpenFOAM Installation | 3 | September 5, 2011 15:52 |
HP MPI warning...Distributed parallel processing | Peter | CFX | 10 | May 14, 2011 06:17 |
IcoFoam parallel woes | msrinath80 | OpenFOAM Running, Solving & CFD | 9 | July 22, 2007 02:58 |
Parallel Computing Classes at San Diego Supercomputer Center Jan. 20-22 | Amitava Majumdar | Main CFD Forum | 0 | January 5, 1999 12:00 |
