December 28, 2007, 03:28 |
Biomass Gasifier
Dear All,
I intend to simulate a down draft biomass gasifier considering it as a porous bed. I would also like to get the pressure drop & temperature across the bed. I would also like to know the gas composition, CV and the temperature of the gas at the outlet. I could model the cold porous bed and get the pressure drop and velocity profiles in the reactor. Further help me out to initiate the chemical reactions. Kindly help me out; your inputs are highly valuable to me. |
April 1, 2011, 03:52 |
CFD modelling of downdraft gasifier
Keran.kp
To, N K Ram
I am Keran patel from Ahmedabad,Studying M tech in Thermal Engg.I've ur thesis of M Tech. which u submitted in 2006-08 under the guidence of Dr. S Maji and Dr. B .B. Arora.. My Project is similiar to urs with a l'ii bit change in model.Bt i can not initiate the combustioin in my model.I kindly request u to help me out.My settings of the model are as below:- Settings : Solver -Pressure Based Formulation -implicit Space -2D Velocity Formulation -Absolute Gradient Option -Green-Gauss Cell Based Porous Formulation -Superficial Velocity Multiphase Multiphase Model : Off Number of phase -1 Energy -Energy Equation Viscous Model Model -k-epsilon (2 eqn) k-epsilon Model -Realizable Near-Wall Treatment -Standard Wall Functions k-epsilon Multiphase Model -Mixture Model Constants C2-Epsilon: 1.9, TKE Prandtl Number: 1, TDR Prandtl Number: 1.2, Disperion Prandtl number: 0.75, Energy Prandtl Number: 0.85, Turb. Schmidt Number: 0.7, Species Model Model -Species Transport Reactions -Volumetric & Particle Surface Options -Inlet Diffusion & Diffusion Energy Source Turbulent -Chemistry Interaction -Finite-Rate/Eddy-Dissipation Operating Condition Pressure: Operating Pressure(pascal)-101325 Gravity: Gravity- Off Hope for the Help ! Thanks in advance |
Problems bout CFD model of biomass gasification, Downdraft gasifier | wanglong | FLUENT | 2 | November 25, 2009 23:27 |
biomass gasifier simulation | rayy | Siemens | 5 | June 9, 2007 04:58 |
combustion model in biomass gasifier | rayy | FLUENT | 1 | January 23, 2007 13:15 |
Biomass Downdraft Gasifier modeling | Aly | FLUENT | 2 | March 30, 2005 12:20 |
Modelling of Biomass gasifier | Sudhahar | FLUENT | 1 | March 26, 2004 04:50 |
