very low drag
Old   January 12, 2008, 01:09
Default very low drag
jamal
dear friends,
i am solving a laminar unsteady flow across a square cylinder which is confined by walls on both sides. ths side of the square cylinder is 10 cm. i exported the mesh to fluent and scaled it to metres.i hav etaken air as my fluid. my reynold no. is 100 and the velocity at that reynold no. is 0.146 m/s. formulation used is implicit. solver used is segregated. ....my problem is that i am getting a very low value of drag..about 0.0003. the correct value is about 1.4.. i could not find where i went wrong. can u help me
thanks a lot
Old   January 12, 2008, 01:52
Default Re: very low drag
Sham
You may want to be careful in the unit conversion. I suggest you model in Gambit using metres and also make sure your ref. values are correct.
Old   January 13, 2008, 23:15
jamal
it worked.... thanks a lot sham..
Negative drag at low y+ rc2v07 CFX 1 July 23, 2008 22:52
CFX analysis of a sphere - drag too low Rob Findlay CFX 6 March 26, 2007 10:11
calculating drag at low Re no over FX airfoil M. Essuri FLUENT 1 November 1, 2006 15:55
Low Drag airfoils for Supermileage vehicle Himanshu FLUENT 1 December 25, 2005 08:51
Multicomponent fluid Andrea CFX 2 October 11, 2004 05:12
