fluent add additional zones for the mesh file
Old   January 24, 2008, 02:31
Default fluent add additional zones for the mesh file
SSL
Hey I read the mesh file for the journal below with fluent then I have a problem when I display the grid I saw fluent add additional zones to the geometry not founded on the actual drawing in Gambit can anybody tell me is the reason from this journal or from where: Journal File for GAMBIT 2.3.16, Database 2.3.14, ntx86 SP2006032921 / Identifier "default_id25012" / File opened for write Tue Jan 15 17:04:21 2008. volume create height 6 radius1 0.02815 radius3 0.02815 offset 3 0 0 xaxis frustum undo /Undone to: volume create height 6 radius1 0.02815 radius3 0.02815 offset 3 0 0 x volume create height 6 radius1 0.027875 radius3 0.027875 offset 3 0 0 xaxis frustum volume create height 6 radius1 0.017875 radius3 0.017875 offset 3 0 0 xaxis frustum volume split "volume.1" volumes "volume.2" connected bientity vertex create coordinates 0 0 0.027875 vertex create coordinates 0 0 -0.027875 edge split "edge.1" vertex "vertex.7" connected edge split "edge.1" vertex "vertex.8" connected edge create straight "vertex.8" "vertex.7" face create wireframe "edge.8" "edge.9" real volume split "volume.1" faces "face.9" connected undo /Undone to: volume split "volume.1" faces "face.9" connected undo /Undone to: face create wireframe "edge.8" "edge.9" real undo /Undone to: edge create straight "vertex.8" "vertex.7" vertex create coordinates 0 0 -0.017875 vertex create coordinates 0 0 0.017875 edge split "edge.5" vertex "vertex.10" connected edge split "edge.9" vertex "vertex.9" connected edge create straight "vertex.8" "vertex.9" edge create straight "vertex.9" "vertex.10" edge create straight "vertex.10" "vertex.7" face create wireframe "edge.11" "edge.12" "edge.13" "edge.8" real volume split "volume.1" faces "face.9" connected undo /Undone to: volume split "volume.1" faces "face.9" connected volume split "volume.2" faces "face.9" connected undo /Undone to: volume split "volume.2" faces "face.9" connected volume split "volume.1" faces "face.9" connected undo /Undone to: volume split "volume.1" faces "face.9" connected undo /Undone to: face create wireframe "edge.11" "edge.12" "edge.13" "edge.8" real undo /Undone to: edge create straight "vertex.10" "vertex.7" redo face create wireframe "edge.12" "edge.9" real volume split "volume.2" faces "face.9" connected face create wireframe "edge.11" "edge.9" "edge.13" "edge.8" real volume split "volume.1" faces "face.1" connected undo /Undone to: volume split "volume.1" faces "face.1" connected undo /Undone to: face create wireframe "edge.11" "edge.9" "edge.13" "edge.8" real redo volume split "volume.1" faces "face.11" connected undo begingroup edge picklink "edge.1" "edge.7" "edge.8" edge mesh "edge.8" "edge.7" "edge.1" successive ratio1 1 size 0.005 undo endgroup undo begingroup edge modify "edge.19" backward edge picklink "edge.19" "edge.18" edge mesh "edge.18" "edge.19" successive ratio1 1.05 size 0.001 undo endgroup undo /Undone to: undo begingroup undo begingroup edge modify "edge.19" backward edge picklink "edge.19" "edge.18" edge mesh "edge.18" "edge.19" successive ratio1 1.05 size 0.001 undo endgroup undo begingroup edge delete "edge.19" "edge.18" keepsettings onlymesh edge mesh "edge.19" "edge.18" successive ratio1 1.05 size 0.0001 undo endgroup undo begingroup edge delete "edge.19" "edge.18" keepsettings onlymesh edge mesh "edge.19" "edge.18" successive ratio1 1.05 size 0.0005 undo endgroup undo begingroup edge delete "edge.19" "edge.18" keepsettings onlymesh edge mesh "edge.19" "edge.18" successive ratio1 1.05 size 0.00075 undo endgroup face mesh "face.1" map size 1 face mesh "face.12" map size 1 face mesh "face.10" pave size 0.002 undo /Undone to: face mesh "face.10" pave size 0.002 face mesh "face.7" pave undo /Undone to: face mesh "face.7" pave face mesh "face.10" "face.7" pave size 0.001 undo /Undone to: face mesh "face.10" "face.7" pave size 0.001 face mesh "face.7" "face.10" pave size 0.005 undo /Undone to: face mesh "face.7" "face.10" pave size 0.005 face mesh "face.7" "face.10" pave size 0.004 undo /Undone to: face mesh "face.7" "face.10" pave size 0.004 face mesh "face.7" "face.10" pave size 0.003 undo /Undone to: face mesh "face.7" "face.10" pave size 0.003 face mesh "face.7" "face.10" pave size 0.0025 undo /Undone to: face mesh "face.7" "face.10" pave size 0.0025 undo /Undone to: face mesh "face.12" map size 1 redo redo undo /Undone to: face mesh "face.7" "face.10" pave size 0.0025 face mesh "face.7" "face.10" pave size 0.00275 undo /Undone to: face mesh "face.7" "face.10" pave size 0.00275 face mesh "face.7" "face.10" pave size 0.003 sfunction create sourcevolumes "volume.1" startsize 0.005 growthrate 1.01 \ sizelimit 0.05 attachfaces "face.1" "face.12" fixed sfunction create sourcevolumes "volume.2" startsize 0.005 growthrate 1.01 \ sizelimit 0.05 attachfaces "face.7" "face.10" fixed /ERROR occurred in the next command! volume mesh "volume.1" "volume.2" cooper /ERROR occurred in the next command! volume mesh "volume.1" cooper source "face.2" "face.5" /ERROR occurred in the next command! volume mesh "volume.2" cooper source "face.7" "face.8" "face.10" undo /Undone to: volume mesh "volume.2" cooper source "face.7" "face.8" "face.10" sfunction delete "sfunc.2" /ERROR occurred in the next command! volume mesh "volume.1" cooper source "face.2" "face.5" sfunction delete "sfunc.1" sfunction create sourcevolumes "volume.2" startsize 0.005 growthrate 1.01 \ sizelimit 0.05 attachfaces "face.7" "face.10" fixed /ERROR occurred in the next command! volume mesh "volume.2" cooper source "face.7" "face.8" "face.10" undo /Undone to: volume mesh "volume.2" cooper source "face.7" "face.8" "face.10" /ERROR occurred in the next command! volume mesh "volume.2" cooper source "face.7" "face.10" undo /Undone to: volume mesh "volume.2" cooper source "face.7" "face.10" undo /Undone to: sfunction create sourcevolumes "volume.2" startsize 0.005 growthrate undo /Undone to: sfunction delete "sfunc.1" undo /Undone to: volume mesh "volume.1" cooper source "face.2" "face.5" undo /Undone to: sfunction delete "sfunc.2" undo /Undone to: volume mesh "volume.1" cooper source "face.2" "face.5" undo /Undone to: volume mesh "volume.1" "volume.2" cooper undo /Undone to: sfunction create sourcevolumes "volume.2" startsize 0.005 growthrate undo /Undone to: sfunction create sourcevolumes "volume.1" startsize 0.005 growthrate undo /Undone to: face mesh "face.7" "face.10" pave size 0.003 undo undo undo undo sfunction create sourcevolumes "volume.1" startsize 0.005 growthrate 1.01 \ sizelimit 0.05 attachfaces "face.1" "face.12" fixed /ERROR occurred in the next command! volume mesh "volume.1" cooper source "face.2" "face.5" undo /Undone to: volume mesh "volume.1" cooper source "face.2" "face.5" sfunction create sourcefaces "face.2" startsize 0.005 growthrate 1.01 \ sizelimit 0.05 attachedges "edge.7" "edge.1" "edge.8" fixed face mesh "face.2" map window modify shade undo /Undone to: face mesh "face.2" map sfunction create sourcefaces "face.2" startsize 0.005 growthrate 1.05 \ sizelimit 0.05 attachedges "edge.7" "edge.1" "edge.8" fixed face mesh "face.2" map undo /Undone to: face mesh "face.2" map sfunction delete "sfunc.1" "sfunc.2" "sfunc.3" sfunction create sourcefaces "face.2" startsize 0.01 growthrate 1.05 \ sizelimit 0.05 attachedges "edge.7" "edge.1" "edge.8" fixed face mesh "face.2" map window modify shade undo /Undone to: face mesh "face.2" map sfunction delete "sfunc.1" sfunction create sourcefaces "face.2" startsize 0.01 growthrate 1.05 \ sizelimit 0.05 attachfaces "face.1" "face.12" fixed face mesh "face.2" map undo /Undone to: face mesh "face.2" map sfunction delete "sfunc.1" face mesh "face.2" map size 0.01 undo /Undone to: face mesh "face.2" map size 0.01 face mesh "face.2" map size 0.05 undo /Undone to: face mesh "face.2" map size 0.05 face mesh "face.5" map size 1 undo /Undone to: face mesh "face.5" map size 1 undo begingroup blayer create first 0.01 growth 1.2 total 0.05368 rows 4 transition 1 trows 0 \ uniform blayer attach "b_layer.1" face "face.2" "face.2" "face.2" edge "edge.7" \ "edge.1" "edge.8" add undo endgroup undo /Undone to: undo begingroup undo /Undone to: sfunction delete "sfunc.1" undo /Undone to: sfunction create sourcefaces "face.2" startsize 0.01 growthrate 1.05 undo /Undone to: sfunction delete "sfunc.1" undo /Undone to: sfunction create sourcefaces "face.2" startsize 0.01 growthrate 1.05 undo /Undone to: sfunction delete "sfunc.1" "sfunc.2" "sfunc.3" undo /Undone to: sfunction create sourcefaces "face.2" startsize 0.005 growthrate 1.05 undo /Undone to: sfunction create sourcefaces "face.2" startsize 0.005 growthrate 1.01 undo /Undone to: sfunction create sourcevolumes "volume.1" startsize 0.005 growthrate undo undo undo undo undo undo undo undo face delete "face.1" "face.7" "face.12" lowertopology onlymesh face mesh "face.7" "face.10" pave size 0.0025 sfunction create sourcevolumes "volume.2" startsize 0.005 growthrate 1.05 \ sizelimit 0.05 attachfaces "face.7" "face.10" fixed volume mesh "volume.2" cooper source "face.7" "face.8" "face.10" undo /Undone to: volume mesh "volume.2" cooper source "face.7" "face.8" "face.10" sfunction modify "sfunc.1" sourcevolumes "volume.2" startsize 0.01 growthrate \ 1.1 sizelimit 0.05 attachfaces "face.7" "face.10" /ERROR occurred in the next command! volume mesh "volume.2" cooper source "face.10" "face.7" /ERROR occurred in the next command! volume mesh "volume.2" cooper source "face.10" "face.7" size 1 undo /Undone to: volume mesh "volume.2" cooper source "face.10" "face.7" size 1 undo /Undone to: volume mesh "volume.2" cooper source "face.10" "face.7" undo /Undone to: sfunction modify "sfunc.1" sourcevolumes "volume.2" startsize 0.01 gr undo /Undone to: sfunction create sourcevolumes "volume.2" startsize 0.005 growthrate undo /Undone to: face mesh "face.7" "face.10" pave size 0.0025 undo /Undone to: face delete "face.1" "face.7" "face.12" lowertopology onlymesh undo undo undo begingroup face delete "face.2" "face.1" "face.5" "face.7" "face.12" onlymesh /ERROR occurred in the next command! face mesh "face.2" "face.1" "face.5" "face.7" "face.12" map undo endgroup /ERROR occurred in the next command! face mesh "face.2" "face.1" "face.5" "face.7" "face.12" map edge delete "edge.19" "edge.18" "edge.10" "edge.9" "edge.8" "edge.7" "edge.5" \ "edge.1" lowertopology onlymesh volume create width 6 depth 0.06 height 0.25 brick volume move "volume.3" offset 3 0 -0.125 volume split "volume.1" volumes "volume.3" connected bientity /ERROR occurred in the next command! volume split "volume.2" volumes "volume.3" connected bientity volume delete "volume.4" lowertopology volume delete "volume.3" lowertopology volume create width 6 depth 0.06 height 0.25 brick volume move "volume.6" offset 3 0 -0.125 volume split "volume.2" volumes "volume.6" connected bientity volume delete "volume.6" lowertopology volume delete "volume.7" lowertopology volume delete "volume.5" lowertopology undo begingroup edge delete "edge.47" "edge.7" keepsettings onlymesh edge picklink "edge.7" "edge.47" edge mesh "edge.47" "edge.7" successive ratio1 1 size 0.0025 undo endgroup undo begingroup edge delete "edge.44" keepsettings onlymesh edge picklink "edge.44" /ERROR occurred in the next command! edge mesh "edge.44" successive ratio1 1.1 size 0.005 undo endgroup edge mesh "edge.44" successive ratio1 1.05 size 0.005 undo /Undone to: edge mesh "edge.44" successive ratio1 1.05 size 0.005 undo begingroup edge modify "edge.44" backward edge mesh "edge.44" successive ratio1 1.05 size 0.005 undo endgroup undo begingroup edge delete "edge.44" keepsettings onlymesh /ERROR occurred in the next command! edge mesh "edge.44" successive ratio1 1.075 size 0.005 undo endgroup undo /Undone to: undo begingroup undo begingroup edge delete "edge.44" keepsettings onlymesh edge mesh "edge.44" successive ratio1 1.05 size 0.0075 undo endgroup undo begingroup edge delete "edge.44" keepsettings onlymesh edge mesh "edge.44" successive ratio1 1.05 size 0.01 undo endgroup undo begingroup edge delete "edge.44" keepsettings onlymesh edge mesh "edge.44" successive ratio1 1.01 size 0.01 undo endgroup undo begingroup edge delete "edge.44" keepsettings onlymesh edge mesh "edge.44" successive ratio1 1.1 size 0.01 undo endgroup undo begingroup edge delete "edge.44" keepsettings onlymesh /ERROR occurred in the next command! edge mesh "edge.44" successive ratio1 1.1 size 0.005 undo endgroup undo /Undone to: undo begingroup undo begingroup edge delete "edge.44" keepsettings onlymesh edge mesh "edge.44" successive ratio1 1.1 size 0.05 undo endgroup undo begingroup edge delete "edge.44" keepsettings onlymesh edge mesh "edge.44" successive ratio1 1.1 intervals 120 undo endgroup undo begingroup edge delete "edge.44" keepsettings onlymesh edge mesh "edge.44" successive ratio1 1.5 intervals 120 undo endgroup undo begingroup edge delete "edge.44" keepsettings onlymesh edge mesh "edge.44" successive ratio1 1 intervals 120 undo endgroup undo begingroup edge delete "edge.44" keepsettings onlymesh edge mesh "edge.44" successive ratio1 1 size 0.01 undo endgroup undo begingroup edge delete "edge.44" keepsettings onlymesh edge mesh "edge.44" successive ratio1 1 size 0.025 undo endgroup undo begingroup edge delete "edge.44" keepsettings onlymesh edge mesh "edge.44" successive ratio1 1.01 size 0.025 undo endgroup face mesh "face.30" map undo /Undone to: face mesh "face.30" map edge link "edge.44" "edge.35" directions 0 0 periodic undo /Undone to: edge link "edge.44" "edge.35" directions 0 0 periodic undo begingroup edge delete "edge.44" keepsettings onlymesh edge mesh "edge.44" successive ratio1 1.05 size 0.025 undo endgroup /Nothing redone by the following redo. redo /Nothing redone by the following redo. redo /Nothing redone by the following redo. redo undo /Undone to: undo begingroup undo /Undone to: undo begingroup redo redo undo /Undone to: undo begingroup undo begingroup edge delete "edge.35" keepsettings onlymesh edge picklink "edge.35" edge mesh "edge.35" successive ratio1 1.01 size 0.025 undo endgroup face mesh "face.30" map window modify shade window modify noshade undo begingroup edge delete "edge.36" "edge.19" "edge.42" keepsettings onlymesh edge modify "edge.36" "edge.19" backward edge picklink "edge.36" "edge.19" "edge.42" edge mesh "edge.36" "edge.19" "edge.42" successive ratio1 1.05 size 0.001 undo endgroup undo begingroup edge delete "edge.19" "edge.42" "edge.36" keepsettings onlymesh edge mesh "edge.19" "edge.42" "edge.36" successive ratio1 1.05 size 0.0001 undo endgroup undo begingroup edge delete "edge.19" "edge.42" "edge.36" keepsettings onlymesh edge mesh "edge.19" "edge.42" "edge.36" successive ratio1 1.05 size 0.0005 undo endgroup undo begingroup edge delete "edge.19" "edge.42" "edge.36" keepsettings onlymesh edge mesh "edge.19" "edge.42" "edge.36" successive ratio1 1.05 size 0.00075 undo endgroup face mesh "face.12" "face.28" map /ERROR occurred in the next command! volume mesh "volume.1" map undo /Undone to: volume mesh "volume.1" map /ERROR occurred in the next command! volume mesh "volume.1" map window modify shade window modify noshade undo /Undone to: volume mesh "volume.1" map face mesh "face.41" "face.42" triprimitive undo /Undone to: face mesh "face.41" "face.42" triprimitive face mesh "face.41" "face.42" triprimitive size 0.003 undo /Undone to: face mesh "face.41" "face.42" triprimitive size 0.003 face mesh "face.41" "face.42" triprimitive size 0.002 undo /Undone to: face mesh "face.41" "face.42" triprimitive size 0.002 face mesh "face.41" "face.42" triprimitive size 0.004 undo /Undone to: face mesh "face.41" "face.42" triprimitive size 0.004 undo begingroup edge delete "edge.63" "edge.61" keepsettings onlymesh edge modify "edge.61" backward edge picklink "edge.61" "edge.63" edge mesh "edge.63" "edge.61" successive ratio1 1.1 size 0.002 undo endgroup face mesh "face.42" "face.41" triprimitive undo /Undone to: face mesh "face.42" "face.41" triprimitive undo /Undone to: undo begingroup undo begingroup edge delete "edge.65" "edge.63" "edge.61" keepsettings onlymesh edge modify "edge.65" "edge.61" backward edge picklink "edge.65" "edge.61" "edge.63" edge mesh "edge.65" "edge.63" "edge.61" successive ratio1 1.1 size 0.002 undo endgroup /ERROR occurred in the next command! face mesh "face.41" "face.42" triprimitive undo /Undone to: face mesh "face.41" "face.42" triprimitive undo /Undone to: undo begingroup undo /Undone to: face mesh "face.12" "face.28" map redo redo /ERROR occurred in the next command! redo /Nothing redone by the following redo. redo /Nothing redone by the following redo. redo /Nothing redone by the following redo. redo /Nothing redone by the following redo. redo /Nothing redone by the following redo. redo /Nothing redone by the following redo. redo /Nothing redone by the following redo. redo undo /Undone to: face mesh "face.41" "face.42" triprimitive undo /Undone to: undo begingroup undo /Undone to: face mesh "face.12" "face.28" map redo face mesh "face.41" triprimitive size 0.0035 undo /Undone to: face mesh "face.41" triprimitive size 0.0035 face mesh "face.42" triprimitive size 0.00275 undo /Undone to: face mesh "face.42" triprimitive size 0.00275 undo begingroup edge delete "edge.63" "edge.61" keepsettings onlymesh edge modify "edge.61" backward edge picklink "edge.61" "edge.63" edge mesh "edge.63" "edge.61" successive ratio1 1.1 size 0.0025 undo endgroup undo begingroup edge delete "edge.63" "edge.61" keepsettings onlymesh edge mesh "edge.63" "edge.61" successive ratio1 1.1 size 0.0005 undo endgroup undo begingroup edge delete "edge.63" "edge.61" keepsettings onlymesh edge mesh "edge.63" "edge.61" successive ratio1 1.1 size 0.001 undo endgroup undo begingroup edge delete "edge.61" "edge.63" keepsettings onlymesh edge mesh "edge.61" "edge.63" successive ratio1 1.1 size 0.0025 undo endgroup undo begingroup edge delete "edge.63" "edge.61" keepsettings onlymesh edge mesh "edge.63" "edge.61" successive ratio1 1.1 size 0.0015 undo endgroup face mesh "face.42" triprimitive undo /Undone to: face mesh "face.42" triprimitive face mesh "face.42" triprimitive size 0.002 face mesh "face.41" triprimitive undo /Undone to: face mesh "face.41" triprimitive undo /Undone to: face mesh "face.42" triprimitive size 0.002 undo /Undone to: undo begingroup undo /Undone to: undo begingroup undo /Undone to: undo begingroup undo /Undone to: undo begingroup undo /Undone to: undo begingroup undo /Undone to: face mesh "face.12" "face.28" map redo undo begingroup edge picklink "edge.38" "edge.41" edge mesh "edge.41" "edge.38" successive ratio1 1.01 size 0.025 undo endgroup undo /Undone to: undo begingroup undo begingroup edge modify "edge.41" backward edge picklink "edge.41" "edge.38" edge mesh "edge.41" "edge.38" successive ratio1 1.01 size 0.025 undo endgroup face mesh "face.5" map volume mesh "volume.1" map window modify shade window modify noshade face mesh "face.41" "face.42" triprimitive size 0.002 volume mesh "volume.2" cooper source "face.42" "face.41" "face.8" window modify shade window modify noshade physics create "Water_In" btype "VELOCITY_INLET" face "face.41" "face.12" physics create "Oil_In" btype "VELOCITY_INLET" face "face.28" "face.42" window modify shade window modify noshade physics create "Outlet" btype "PRESSURE_OUTLET" face "face.29" "face.8" physics create "Low_Re" ctype "FLUID" volume "volume.1" physics create "RSM" ctype "FLUID" volume "volume.2" physics create "Pipe_Wall" btype "WALL" face "face.30" save name "C:\Oil_water.dbs"
Old   January 24, 2008, 07:01
Default Re: fluent add additional zones for the mesh file
SSL
I sent the journal again to be more understandable:
Old   January 26, 2008, 11:55
SSL
any help with my last request?
How to open Icem mesh in Ansys Fluent? emmkell FLUENT 27 February 6, 2018 03:34
pisoFoam compiling error with OF 1.7.1 on MAC OSX Greg Givogue OpenFOAM Programming & Development 3 March 4, 2011 17:18
[blockMesh] BlockMesh FOAM warning gaottino OpenFOAM Meshing & Mesh Conversion 7 July 19, 2010 14:11
OpenFOAM Install Script ljsh OpenFOAM Installation 82 October 12, 2009 11:47
[OpenFOAM] Paraview command not found hardy ParaView 7 September 18, 2008 04:59
