CFL
Old   February 25, 2008, 07:00
Default CFL
thuy
Hi, I simulated my model with the adaptive time stepping. I'd like to know the value of CFL. How can I do ? Thanks
Old   March 14, 2008, 03:05
Default Re: CFL
Ramesh. K
cfl is the ratio of fluidspeed to grid speed, and it should be in between 0 and 1 so you will be knowing the speed of the fluid u are using and the grid size choose an appropriate time step such that u get cfl in this range
Old   March 14, 2008, 03:59
Default Re: CFL
thuy
Hi, Thanks for your reponse, Remesh. I agree with you about the CFL's definition. But I'd like to know the values of CFL which are provided by Fluent. Finally, I found them. In case you need the values, you can find them in :Contours--> Velocity--> Cell Courant Number.
Thuy
CFL number in steady simulations Rol Main CFD Forum 4 August 20, 2010 09:17
CFL number for Navier-Stokes (Infinite? How large?) gory Main CFD Forum 6 April 30, 2009 19:51
how to set CFL number in FLUENT xiaofish FLUENT 1 October 12, 2007 04:51
implementing the CFL criterion Ben Houston Main CFD Forum 1 December 4, 2002 10:16
CFL limits for separated flow Bigarella Main CFD Forum 3 August 11, 2002 07:22
