turbulent viscosity ratio on a large duct
Old   March 5, 2008, 00:23
Default turbulent viscosity ratio on a large duct
newbie
I searched the forum but I couldn't quite get the answer to my problem.
I ran a simulation where water flows through a very large square duct (5x5x30m).
solver: k epsilon standard Inlet: velocity inlet 1 m/s duct wall: smooth wall outlet: outflow
Mesh: quad mesh with 0.3 size (resulting in about 50,000 nodes). gravity on. specified operating density=0
The problem gets the turbulent viscosity limit error (1e5). Strange thing is that when I plotted viscosity ratio, almost all of the water body not close to wall had viscosity ratio around 1e5. How could this be so high in such a simple flow? Is this normal?
Old   March 5, 2008, 02:36
Default Re: turbulent viscosity ratio on a large duct
Robert
Hi, I think, the FLUENT wrote the following (because this is usually): "Turbulent viscosity RATIO limited to 1e5 in ... cells". You can not (as I know) plot the ratio, only the viscosity, which isn't the same.
You can set the limits in the Solve/Controls/Limits.
Bye
Old   March 5, 2008, 12:27
newbie
I really did plot the ratio. To to like pathline or vector or contour, click the turbulance, and than on the below, click the turbulent viscosity ratio.
newbie
Old   March 7, 2008, 16:00
Default Re: turbulent viscosity ratio on a large duct *NM*
shehab
Old   March 7, 2008, 16:05
shehab
may be if you set the specified density to 1000 kg/m^3 this should work. you can't set the specific density to zero. either to deactivate it or to set it as equal to the highest density phase and as you simulate a single phase then you should set it as the density of the water. also what do u mean by smooth wall... is it slipping wall... then try to set it no slip condition. best regards, shehab.....shebos@hotmail.com
RSM+2nd ordedr causes turbulent viscosity limited to viscosity ratio of.... khsiavash Main CFD Forum 10 January 7, 2016 12:30
turbulent viscosity ratio for jet serpil FLUENT 3 September 19, 2014 06:19
Turbulent viscosity ratio lost.identity Main CFD Forum 8 May 13, 2009 05:55
Turbulent viscosity ratio whit sails javier FLUENT 0 February 2, 2004 11:48
On limiting to turbulent viscosity ratio! varghese FLUENT 2 November 15, 2003 08:56
