Continuity si not converged
Old   March 5, 2008, 09:13
Default Continuity si not converged
Cristiano
I'm modelling a gas turbine combustor with an unstructured grid. I've got a problem for the continuity residuals. I don't think it's a problem related with the grid.
Old   March 5, 2008, 09:18
Default Re: Continuity is not converged *NM*
Cristiano
Old   March 5, 2008, 09:20
Default Re: Continuity si not converged
Robert
Maybe...but many things can cause it.
Old   March 5, 2008, 10:23
Default Continuity is not converged
Cristiano
I tried several unstructured grid (sensitivity analysis). Could I change under relaxation factor?
Old   March 5, 2008, 13:03
Robert
Decreasing of under relaxation factor usually help. Especially the Momentum under relaxation factor.
Old   March 6, 2008, 19:50
Hirdesh
Decrease under relaxation factor. first momentum, if it not sufficient then try with pressure also.
How to write k and epsilon before the abnormal end xiuying OpenFOAM Running, Solving & CFD 8 August 27, 2013 15:33
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 bookie56 OpenFOAM Installation 8 August 13, 2011 04:03
Convergence moving mesh lr103476 OpenFOAM Running, Solving & CFD 30 November 19, 2007 14:09
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 02:58
Could anybody help me see this error and give help liugx212 OpenFOAM Running, Solving & CFD 3 January 4, 2006 18:07
