fluent
Old   March 13, 2008, 10:10
Default fluent
natali
I need create boundary conditions for a face but this boundary conditions depend of a pressure. I have a pressure with a sin function. So I need: when pressure is negative la surface is a wall but when de pressure is positive la surface is an exit of gas an escape. Can you help me???? it's urgent
Old   March 13, 2008, 11:44
Default Re: fluent
Dave
I'm not aware that Fluent can model this using its standard boundary conditions - you might need to code it as a UDF. Although I have experience at writing UDFs I would not know how to change boundary condition types while Fluent is running.
Old   March 13, 2008, 11:52
Default Re: fluent
natali
ok thanks but i just want to know how i can assign types of boundary conditions like walls or pressure with UDF. F_FUITE (f,thread)= wall???? or somethings like that????
Old   March 13, 2008, 12:57
Default Re: fluent
mAx
If your BC is unsteady, then you can change the type of your BC, by using a dynamic mesh fonctionnality. (events) I never used it, but I think you can do something with that. http://www.engres.odu.edu/Applicatio...e403.htm#58606
Fluent in Linux vs. Fluent in Windows Melih FLUENT 6 November 16, 2014 09:39
Fluent/Unix vs. Fluent/Windows sjjaber FLUENT 10 January 5, 2005 16:58
Running FLUENT 6.0 sims. on FLUENT 6.1 ozgur FLUENT 2 April 2, 2004 13:23
