How to choose a good model for multiphasis flow ?
Old   April 15, 2008, 03:40
Default How to choose a good model for multiphasis flow ?
Yasmail AKARIOUH
hello
i wish to simulate a truck in a multiphasis flow with a 2D geometry. the principal phase is air and the other one is water liquid. the multophase model is mixture. the problem with this modelisation is that the turbulent viscosity increase enormously. indeed, there is a swirl which is created by the truck. residuals converge for very little water particles ( average 1e-5m). however, residuals become "crazy" for larger water particles. i have modified under-relaxation number but the calculus is diverging. i have tested this model with k-espilon and k-omega viscous model. all of them diverge.
some one has ever done a simulation like mine ?
do you have any idea about dirverging reasons ?
thank you for your answers.
yasmail
Old   April 18, 2008, 12:52
Default Re: How to choose a good model for multiphasis flo
vk
you may try transient run with large time step instead od steady state. Hope this may give better results.
Old   April 21, 2008, 02:12
Yasmail AKARIOUH
time step increasing doesn't any result. the matter of this model is the water-liquid drop size. indeed when i use a diameter inferior to 10^-5 m, residuals converge. however for a 10^-3 m drop the model is totally instable. it's due to the increasing of the turbulent viscosity. this message appears during calculation " turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 202602 cells". i ever try to reduce the under-relaxation number for viscosity, but it does not work. i submit this problem to fluent-support, but they do not give me an answer. they probably hope i will forget.
Which turbulence model to choose? Si Del FLUENT 3 February 8, 2008 04:24
How to choose proper reaction model? jisel FLUENT 0 April 18, 2006 11:11
Which model should I choose when I don't known the Jeff FLUENT 0 June 19, 2005 10:59
what boundary do I choose for the counter-flow ? Gali FLUENT 0 October 20, 2004 05:44
How to choose the buoyancy model? ben Phoenics 2 April 8, 2002 04:04
