April 21, 2008, 09:42 |
help me! Fluent
Hi people! When I plot the vectors velocity in the central axe in fluent appear dislocated vectors, or either, some vectors are disordered, why? thanks a lot
April 21, 2008, 10:25 |
Re: help me! Fluent
if you have an axysymetric problem use display¨...views..camera aand turn ur pattern
April 21, 2008, 10:30 |
Re: help me! Fluent
Hi, my problem is symetric. the vectors are not lined up with the mesh that I made
April 21, 2008, 10:36 |
Re: help me! Fluent
go to display, vectors:go to vectors option check in plane also you can change the scale head..try this
April 21, 2008, 10:41 |
Re: help me! Fluent
thanks for its aid but the problem is not this. when I eye the mesh only exists diagonal lines that would not have to exist
April 21, 2008, 10:42 |
Re: help me! Fluent
thanks for its aid but the problem is not this. when I eye the mesh exists diagonal lines that would not have to exist
Fluent in Linux vs. Fluent in Windows | Melih | FLUENT | 6 | November 16, 2014 09:39 |
Fluent/Unix vs. Fluent/Windows | sjjaber | FLUENT | 10 | January 5, 2005 16:58 |
Running FLUENT 6.0 sims. on FLUENT 6.1 | ozgur | FLUENT | 2 | April 2, 2004 13:23 |
