April 28, 2008, 08:13 |
Discrete Phase Modeling
Hey,
I have a problem in Fluent. I'm modeling particles in an airflow, and I get a number of particles that is incomplete. I have allready increased the max number of steps to the limit (1e+9). What can I do? Thx |
April 28, 2008, 09:05 |
Re: Discrete Phase Modeling
try to reduce length scale.
April 28, 2008, 09:46 |
I tried, it didn't work
April 28, 2008, 11:14 |
The DPM does not work well for particles with very long residence times. You should try the eulerian-eulerian multiphase model.
April 28, 2008, 11:22 |
Re: about Discrete Phase Model in spray cooler
i doing project in discrete phase model (water droplet) impinge on continuous phase model (hot gases) to reduce temperature of (hot gases)continuous phase.that is employ on spray cooler.i want your help as early as possible.my mail id:mechgbalaji@yahoo.co.in
April 28, 2008, 11:32 |
and how can i check the residence time?
April 28, 2008, 23:00 |
Hey, Ebrahim. In DPM model, Incomplete trajectories are those that were terminated when the maxium allowed number of time stepes was exceeded. You can adjust maximum number of steps for the particles. However, the number of incomplete trajectories sometimes can not be diminished, in one of my case, 10% particles are incomplete whatever how i adjust the maxium number. And in another two cases with the similar geometry model, the incomplete number is 0, and the aborted number is about 1%. So I think the incomplete particle fate has relation with the complexity of the geometry shape of your case.
I'll send u a ppt about the introduction of DPM. |
species transport and discrete phase modeling .... | farhath | FLUENT | 2 | February 11, 2006 01:09 |
Discrete Phase Modeling | revanth | FLUENT | 8 | July 18, 2002 05:30 |
Discrete Phase Modeling | Chris | FLUENT | 0 | November 20, 2000 13:08 |
Discrete Phase Modeling | Fred Kang | FLUENT | 3 | October 18, 2000 10:23 |
Discrete Phase Modeling | X.Tang | FLUENT | 0 | April 25, 2000 08:17 |
