April 29, 2008, 06:33 |
import geometry in GAMBIT
Import geometry realized in Solidworks (Parasolid, IGS).
In GAMBIT : ERROR: Translation requires license feature geom-trans. What can I do? |
April 29, 2008, 07:07 |
Re: import geometry in GAMBIT
in Gambit, .igs can be imported without problem. make sure that you save a .igs file.
April 29, 2008, 08:57 |
I import *.igs. But I have to specify native (no spatial). What does it mean?
April 29, 2008, 09:02 |
you don't need to specify anything, just take your igs file, and click accept. let default set a .igs ( if you open it with bloc note)is a file where are written geometry "action" ( like point creation etc.)
April 29, 2008, 09:22 |
But... If I don't specify native... I can't open igs file
April 29, 2008, 09:26 |
would you like to send me your .igs by e-mail? I will try to open it. yasmail.akariouh@volvo.com
April 29, 2008, 10:22 |
this is a license problem
November 12, 2011, 10:06 |
Emre G
how can we complete that problem?
thanks |
November 14, 2011, 16:33 |
Juraj
I have the same problem.
November 14, 2011, 17:20 |
raj
I feel this is a license error, make sure your translators are in place. More-Over there should not be any problems in importing igs/iges, stp/step, parasolid etc. If the igs doesnot import try using step/stp or parasolid format. Most of the CAD softwares can export in quite a good number of formats that can be imported in GAMBIT.
November 15, 2011, 04:55 |
#11 |
Juraj
InterOp CatiaV5 translator not installed. Check environment INTEROP_LIB_3DX
this is my problem. I can not read the geometry from catia V5R20 into gambit. How i can fix this?? |
November 15, 2011, 05:31 |
#12 |
Emre G
i know that there is a better way to include a "translator feature" in gambit licence, but i dont know how.
İs there anyone cabaple of rewriting the feature specificiations which are desired in gambit licence .dat? |
November 15, 2011, 05:53 |
#13 |
Juraj
emreg,
are you using same social nets? for example facebook. I am user and my name is Juraj Saniga, slovakia, photo with bike. We can conect there, if you want. |
November 15, 2011, 08:29 |
#14 | |
Emre G
thanks for ur reply.. i dont hav an account on facebook. Could u plz send me the procedure how you solved the problem by email? emregungor@hotmail.de i would be very happy if u help me.. |
January 15, 2012, 13:07 |
import geometry in Gambit
#15 |
Hey, I'm having the same problem. I've tried IGES, ACIS, Parasolid and STEP, but I always have the error:
In GAMBIT : ERROR: Translation requires license feature geom-trans. How did you guys fix it? Thanks |
November 6, 2014, 17:43 |
change the date back, about 2010.
#16 |
davoud hassanzadeh
April 6, 2012, 10:02 |
#17 |
Emad Tandis
Hi
I have this problem, too. In GAMBIT : ERROR: Translation requires license feature geom-trans. I know it is about license. because I had a license before, and with that I didn't have this problem. but now, it has been delete. Can you help me? Thanks |
June 25, 2012, 04:39 |
#18 |
mohammad reza
Hi
I had a a problem like this and I tried varies versions of Gambit. Finally when a changed the input file's path, it worked. My input (parasolid *.x_b) file's directory contained spaces and when I changed it, it worked with gambit 2.2.3 |
June 25, 2013, 02:27 |
translator in gambit
#19 |
vignesh
Rep Power: 12 |
hi i am also having the same problem when i tried to upload my catia v5 files into gambit. i dont know whether i have installed the translator license or not. so please tell me how to check it and solve the problem.............
August 19, 2013, 08:13 |
gambit translator
#20 |
David
Rep Power: 12 |
i have problem with my gambit license file, when i import my
configuration from CATIA v5 to gambit, i have this error: translation failed. translator requires license feature geom-trans. can anyone helps me? |
Import 2D Geometry to Gambit | Nathan | ANSYS Meshing & Geometry | 3 | March 27, 2017 10:26 |
Import geometry in GAMBIT | Cristiano | FLUENT | 4 | April 21, 2008 05:42 |
GAMBIT, CAD import, clean up geometry problem | Nuray Kayakol | FLUENT | 1 | December 30, 2007 11:43 |
iges geometry file gambit import | giacomo | FLUENT | 0 | May 14, 2007 12:32 |
Multiple import of Geometry in GAMBIT(Catcon Simu) | Amod kumar | FLUENT | 0 | July 21, 2006 23:55 |
