Journal files - Batch mode
Old   April 29, 2008, 04:43
Default Journal files - Batch mode
Rémi GOULET
I make a flow calculation in a simple layout.
But, i need to take the outlet temperature and velocity profiles and use them as inlet profiles for the next calculation (same layout).
I need to repeat this process 70 times.
I know journal files enable to manage this problem.
But i don't know how to construc a loop in scheme programming
Does anybody know it?
Thanks.
Old   April 29, 2008, 05:37
Default Re: Journal files - Batch mode
mAx
here on example:
(define start 1) (define ende 9) (do ((n) (i start (+ i 1))) ((= i (+ ende 1)) n) (ti-menu-load-string (format #f "file read-data test000~a.dat yes" i)) (ti-menu-load-string "file read-journal post.jou") (ti-menu-load-string (format #f "display hard-copy test~a.tiff" i)) )
Old   April 29, 2008, 05:41
Rémi GOULET
Thank you very much mAx, and how can I save results (for example outlet temperature profiles) at each iteration
Thanks for your answer.
Old   April 29, 2008, 06:21
mAx
File/Write/Profile
Old   April 30, 2008, 17:06
Ralf Schmidt
hi!
there is a cfd wiki about that:
http://www.cfd-online.com/Wiki/Fluen...ournal_file.3F
hope, it helps Ralf
Batch Mode Titiksh Patel FLUENT 13 February 1, 2010 14:48
pb with batch mode philippe FLUENT 2 October 21, 2008 17:39
cleaning gambit journal file in batch mode HK FLUENT 0 April 1, 2008 20:35
Batch mode Achim Frahm Phoenics 0 July 25, 2003 12:14
Batch mode swapnil CFX 5 November 23, 2002 09:38
