May 9, 2008, 06:03 |
punched zone and porous model
I'm modeling a gas turbine combustor. The punched zones on the liner are modeled with porous model (alfa=0; calibration with CR). I don't understand the difference between superficial velocity and physical velocity. In my case: 1)In each zone I imposed the porosity (Gamma)parameters. 2)Then I changed CR with the superficial velocity option to calibrate the model (based on fluxes distribution)... 3)The run with physical velocity in postprocessor shows the different fluxes distribution and if I modify CR nothing changes.
Help me. I'm going crazy |
May 12, 2008, 12:22 |
Re: punched zone and porous model
A porous media condition for a volume needs to have the correct parameters entered:
http://www.fluentusers.com/fluent/do...ug/node276.htm http://www.fluentusers.com/fluent/do...ug/node277.htm |
UDF for Porous Zone | Evan | FLUENT | 1 | October 21, 2011 02:24 |
Porous jump & Porous zone - help needed | Witsarut Jintaworn | FLUENT | 3 | June 14, 2010 22:37 |
Using porous zone to model tube ribs in 2D??? | PAD | FLUENT | 0 | August 17, 2006 06:08 |
porous zone again | Edward Roj | FLUENT | 0 | May 10, 2005 07:11 |
Porous Zone | Chico Mbanu | FLUENT | 1 | July 21, 2004 07:23 |
