solution is too dependant on system environment.
Old   May 14, 2008, 13:31
Default solution is too dependant on system environment.
Happyday19c
I tested a simple cylinder case(inviscid) on a different system environment. But the solution was very different and residuals are not identically same.
Which one is reliable solution? Anyone helps me please..
Test Case : 2-dimenstional Cylinder Flow Test System :
1. Intel Core2Duo E4500@2.2GHz, 2GB RAM
32bit version of FLUENT 6.3.26
Testing Serial, Parallel -t2 option 2. Intel Core2Extreme QX9650@3.0GHz, 8GB RAM
64bit version of FLUENT 6.3.26
Testing Serial, Parallel -t2, -t3, -t4 option
Transcript files and Case file link is below...
http://cid-bb333e83248181b9.skydrive...com/self.aspx/%ea%b3%b5%ec%9a%a9
time dependant accelerations khartoumi said FLUENT 0 November 3, 2006 07:09
Time dependant parameters Madhukar Rapaka FLUENT 1 August 24, 2005 18:42
Full System Solution Provider? Donald Casteel Main CFD Forum 0 April 13, 2003 12:44
Time Dependant solution phil FLUENT 3 January 9, 2002 12:14
