libudf directory Problem
Old   May 27, 2008, 09:24
Default libudf directory Problem
Dennis
Hello everybody,
I am having some problems with compiling an UDF in parallel version on Linux. The case- and the udf-file are in the same folder (/data/project/test). When I compile the UDF I don't get an error message, but when I try to load it, the following error appears for each node: Opening library "libudf"... Error: open_udf_library
When I look now inside the folder with the cas-file the libudf-folder was created. If I know copy the created libudf-folder and copy it to: /data/project and then building the udf suddenly works.
The working file from Fluent is set to this directory where I have to copy the libudf-folder: /data/project So my question is, why do I have to copy the libudf-folder to this place?
I hope the explanation of the problem was understandable and anyone has an idea. Thanks in advance
Kind regards, Dennis
load libudf problem alfred Fluent UDF and Scheme Programming 24 October 31, 2013 23:53
Opening library "libudf"... beginner FLUENT 0 August 20, 2007 18:03
a libudf must be built? wanghong FLUENT 0 September 9, 2005 08:10
Question about libudf file zhou1 FLUENT 1 January 29, 2004 08:22
error setting up libudf andrew_garrard FLUENT 4 August 19, 2003 10:17
