Dispersed Solid particles in carrier gas (DPM) |
June 1, 2008, 06:59 |
Hy,
I want to simulate a carrier gas jet flow with solid spherical particles... The solid particles ar carried by the gas flow..There is no reaction between those two phases. and the flow of the continus phase is to be turbulent. I want to inject both continuous gas and solid particles from the injector at the same position ( I use velocity inlet BC for the gas phase ) How can I do that and should I use a Steady or unsteady model ? Shoud I use a one coupling way approach ? thanks in advance for any help or suggesion Fred |
June 3, 2008, 05:13 |
Re: Dispersed Solid particles in carrier gas (DPM)
you can refer to: http://www.cfd-online.com/Forum/flue...cgi/read/28699 i think it's useful for us
can you have variable density for solid dispersed? | Tim | CFX | 0 | August 13, 2008 01:11 |
Viscosity for solid dispersed phase in E-E modelin | Kushagra | FLUENT | 0 | June 27, 2008 19:01 |
coefficient of restitution for solid particles | Michelle | CFX | 2 | March 19, 2008 23:36 |
solid particles | sacha | CFX | 5 | November 10, 2003 12:29 |
DPM - Melting of Solid particles | Devin | FLUENT | 0 | September 12, 2002 11:42 |
