How to make boundary layer mesh moving with wall
Old   June 7, 2008, 10:38
Default How to make boundary layer mesh moving with wall
wayne
Hi everyone. i want to make a simulation with moving boundary with Dynamic mesh.some thing like flow pass an oscillant circule cylinder. i want to simulate the moving of cylinder in dynamic mesh method.but i want to make a precise simulation of vortex shedding,so i want a good boudary layer mesh during the moving procedure.but when the cylinder moving the mesh changes,how can i make the boundary layer mesh moving with the cylinder?
thanks!
yours wayne
Old   June 11, 2008, 12:20
Default Re: How to make boundary layer mesh moving with wa
red lemon
Fix the boundary layer cells using a TUI command only. I think its spring-on-all-shapes but check the Fluent UG.
Old   June 11, 2008, 12:48
wayne
what is fluent UG? which commond? is there any help on that?
Old   June 11, 2008, 23:23
suvash
Fluent UG means Fluent User Guide...
[mesh manipulation] Moving Mesh engineFoam Addremove layer gbracing OpenFOAM Meshing & Mesh Conversion 1 February 18, 2009 04:35
[mesh manipulation] Moving Mesh Addremove layer gbracing OpenFOAM Meshing & Mesh Conversion 1 February 12, 2009 11:12
Deal with wall boundary with moving mesh by FVM? aiya Main CFD Forum 6 May 10, 2007 11:33
Wall turbulence, viscosity, boundary layer Patrick Godon Main CFD Forum 1 November 5, 2003 15:39
boundary layer upon viscous wall Xavier TRICOT Main CFD Forum 2 September 20, 2000 04:40
