June 9, 2008, 12:47 |
TGrid PArallel
Does anyboby know if TGrid is able to run in parallel??
June 9, 2008, 16:48 |
Re: TGrid PArallel
No it is not... Why do you need it?
June 9, 2008, 21:22 |
Re: TGrid PArallel
I need it for refining a model in two processors. What is the principal reason because Tgrid does not work in parallel??
June 10, 2008, 14:52 |
Re: TGrid PArallel
Why do need to refine it on two CPUs? Speedup reasons?
The reason is that FLUENT/ANSYS has not yes parallelised it.... |
June 10, 2008, 20:09 |
Re: TGrid PArallel
speed up simply, and I have the doubt simply, because if fluent can run in parallel. why Tgrid doesn't?
June 11, 2008, 01:12 |
Re: TGrid PArallel
Fluent solver runs on parallel but not the Post processing. You can only solve using parallel computation not setting up the model and pre-processing the results.
June 11, 2008, 12:17 |
Re: TGrid PArallel
You can in fact setup, solve and post process in parallel in Fluent. Some functionality is restricted when doing post in parallel such as deactivate cell zones on partitioned grid but for the most part you can do all 3 in parallel and not just the solve.
TGrid is only a serial product but using 64 bit you can generated >100million cell meshes. Note that ANSYS ICEM can be used in parallel on a multi cpu machine. |
June 11, 2008, 13:55 |
Re: TGrid PArallel
icem can be used in paralell only for tetrahedral meshing
June 12, 2008, 03:13 |
Re: TGrid PArallel
#9 |
Thank you for the onformation Red Lemon! Fluent post and set up lienses do get opened on parallel. But while keeping note of the CPU usage, I could not see the CPUs (nodes) loaded other than the master one. So thought the other CPUs are just connected but not used. But it may be because of size of my model (only 11 million hybrid cells!).
tgrid | hamireza ahmadi | FLUENT | 3 | December 13, 2008 06:05 |
Need help with TGrid | HSeldon | FLUENT | 0 | August 22, 2007 11:41 |
Tgrid | ricky | FLUENT | 3 | August 20, 2007 20:54 |
Tgrid 4.0 | TomK | FLUENT | 1 | January 21, 2006 02:32 |
Tgrid | Boris | FLUENT | 0 | April 2, 2002 20:02 |
