June 12, 2008, 10:04 |
plz help:"outflow" BC problem
hello, Am trying to find the HTCs in circular jet impingement cooling of air on a metal plate. The inlet is thru a nozzle of dia 1" and the outflow is thru the curved area of cylinder dia 10" and height 2". The outlet boundry condn is "OUTFLOW". It's creating a lot of convergence issues bcoz there is back flow, actually there is recirculation, is the reverse flow because of that, will it be solved if i increase my domain.
_____________________| ! |_______________________ <----.................................................. .................................-------> _______________________________________________ <--the cooled plate Another q is that can i use two symetric BC to model a circular section of 30 deg like this" <)" hope you got it |
June 12, 2008, 17:12 |
Re: plz help:"outflow" BC problem
Move outlets further away to capture recirculation and use stagnation pressure (pressure outlet) condition instead.
On second point you can use rotational periodics for that. Both flat faces represent the periodic zone and these can be conformal or non conformal in fluent. If you can guarantee (big if!) that flow is axial then don't use periodic sector with symmetries as you can model as 2D axi-symmetric as it will solve quicker. Otherwise use the 3D periodic approach described. This latter option may be the safer one. |
is there mass outflow or velocity outflow B.C. | kk | FLUENT | 1 | April 12, 2007 10:55 |
Outflow BC | ramp | FLUENT | 1 | May 10, 2006 04:26 |
Velocity outflow vs Pressure Outflow | ramesh | Siemens | 1 | January 9, 2006 01:12 |
Inflow/outflow problem | Julie Polyakh | Siemens | 1 | January 27, 2002 09:30 |
outflow BC | Niklas | FLUENT | 2 | December 25, 2001 11:42 |
