how to define restituition coefficient using UDF?
Old   July 2, 2008, 11:08
Default how to define restituition coefficient using UDF?
haijj
hi, everyone~~~
in many simulations for gas-solid flows, the restituition coefficient (e) is always treated as a constant. But some researchers considered that e was the function of voidage, so I want to know how to modify the restitution coefficient using UDF. I check the help files provided by Fluent, but cannot find the solution. Could anybody help me? thanks very much~~~~
Old   July 2, 2008, 11:24
Default Re: how to define restituition coefficient using U
Paul
I'm not sure but try
DEFINE_EXCHANGE_PROPERTY
Paul
Old   July 2, 2008, 21:45
haijj
thanks~~~
which file in src can we find the definition of restitution coeff.?
Old   July 2, 2008, 22:58
Paul
I don't know where in the src could you find the definition of the restitution coefficient.
In GUI the restitution coefficient could be changed at Phases->Interactions->Collisions.
In a UDF you could change the restitution coefficient by changing the model of interactions in phases.
Anyway this is how I would try to define a variable restitution coefficient:
The interaction drag between two solid phases is modeleted in Fluent by symlal-obrien-symmetric, this model uses the constant restitution coefficient provided by you in GUI at Collisions.
Pick the relations for this model, implement the model in a UDF as a DEFINE_EXCHANGE_PROPERTY and use your relation for the restitution coefficient.
Then you could hook your function instead of the classic symlal-obrien-symmetric.
Paul
Old   July 7, 2008, 00:38
Woo Meng Wai
An alternative is to re-write the whole REFLECT particle boundary condition model using DEFINE_DPM_BC (can be foudn in the UDF manual). The example given in the UDF manual corresponds to the REFLECT condition. You can then add your mathematical description of the restitution factor in the UDF.
Might or might not be the best way. Do let us know.
Best regards, Woo
Old   July 8, 2008, 22:46
haijj
thanks, but the model I use is Eulerian-Eulerian, not DPM
Old   July 9, 2008, 23:26
haijj
can anyone help me? thanks
define mass transfer - define source greg FLUENT 4 November 24, 2018 06:34
How t o define head loss coefficient?pls urgent. mitesh FLUENT 0 January 20, 2006 09:14
how to define argon'diffuse coefficient? wanghong FLUENT 0 April 5, 2005 08:49
define my own DEFINE macro? to model pithing naca calogero FLUENT 0 April 10, 2003 05:10
How to define the effective coefficient in Q1 jealous Phoenics 0 December 25, 2002 09:41
