Can I use VOF with MRF at same time?
Old   July 3, 2008, 21:34
Default Can I use VOF with MRF at same time?
multiphase-flow
I am modeling air-water flow pattern in a stirring tank. Since there are pitch blades and rushton blades in the tank, I select Multiple Rotating Reference Frames (MRF). I simulated single water phase flow first, it works fine. The inner fluid is moving frame and outer fluid is stationary (interior face between two fluids). I got good results. Now I am adding gas phase into picture. So I turn on the VOF model with MRF, but all residuals increase to 1E+5 with using 0.001 second time step size. Is it problem with initial patch or other problem? When I patch the region for gas phase, I saw both inner fluid (refernce frame) and outer fluid. Should patch gas phase in both regions or separtely? Thank you in advance?
Old   July 9, 2008, 21:55
Default Re: Can I use VOF with MRF at same time?
multiphase-flow
up, need help, thanks
Is there a way to write the time step size, time a may FLUENT 6 November 22, 2009 11:52
Time step in time explicit solver Simon FLUENT 1 August 5, 2009 10:32
Long time CHT transient simulation time step.... JP CFX 0 May 9, 2008 03:36
autosave at flow time with adaptive time stepping Ybes FLUENT 0 November 3, 2007 12:32
Relation of computational time step with real time Salman Main CFD Forum 2 August 3, 2005 14:13
