Wall boundary conditions for 3d-cylinder
Old   July 8, 2008, 08:55
Default Wall boundary conditions for 3d-cylinder
Martin Bellmann
I defined a simple 3d cylinder geometry in fluent. The wall temperature boundary conditions are defined by profiles T=f(x,y,z). z is the height of the cylinder. Now fluent is interpolating on the basis of a cartesian coordinate system and gives not the right temperature field. The temperature should be the same at the peripheries at the cylinder wall and only vary with the height z. Is there a way to define a 3d cylindrical coordinate system just to interpolate the boundary values in the right way?
Old   July 11, 2008, 13:04
Default Re: Wall boundary conditions for 3d-cylinder
umesh javiya
you can also write UDF for defining Temperature profile for boundary condition.....
Both methods are right...as long as ur getting right answer....
wall boundary conditions sivaramakrishnaiah CFX 2 August 21, 2008 10:25
Wall Boundary Conditions Ana Raquel Rosado FLUENT 3 November 8, 2006 22:18
k-epsilon wall boundary conditions Iain Barton Main CFD Forum 0 September 18, 2006 12:13
Wall Roughness Boundary Conditions Tarnz FLUENT 0 January 24, 2005 15:07
wall boundary conditions sourav FLUENT 1 October 24, 2004 21:38
