calculation of heat transfer with defined Humidity
Old   August 21, 2008, 03:10
Default calculation of heat transfer with defined Humidity
dev....
Hi all
I want to get temperature distribution on flat plate having some definite temperature. I have an enviornment of CO2 aourn the flat plate with Relative humidity of 70% . Temperature of flat plate is less than the enviornmental temparature (let say temp difference is 10 deg Centigrade). Can any body tell me, 1. which model i should choose for analysis in fluent. 2. what BC i must apply.
yours suggestions would be appreciable & thanks in advance if any body can help regard same.
Calculation of heat transfer coefficients uli_u OpenFOAM Running, Solving & CFD 16 November 25, 2009 10:41
Calculation of Heat Transfer coefficient sachin CFX 2 February 16, 2009 02:24
conjugate heat transfer with humidity effect? Pei-Ying Hsieh Main CFD Forum 0 September 11, 2008 21:53
Heat transfer/ Temperature calculation Novice FLUENT 0 July 3, 2008 07:24
Turbulent heat transfer calculation Frank Rubensdorffer FLUENT 2 May 29, 2002 14:37
