dynamic mesh
Old   August 24, 2008, 16:14
Default dynamic mesh
Tamjid
hi fellows,
i am having problem of negative cell volume when try to move an object at speeds more than 0.5 mach. i am using DEFINE_DG_MOTION macro in a UDF ,WHICH I COMPILED & HOOKED INTO FLUENT. i used k-epsilon turbulence model.
please enlighten me.
thanks.
Old   August 25, 2008, 00:09
Default Re: dynamic mesh
doki
I think before any try on the solution, you should first make sure your meshing procedure in fluent is ok! because there are some parameters to set in the dymanic mesh window, which usually we do not know their exact values, there comes at least a Trial & error procedure to find the right values for the parameters. Having done this, one should check the mesh motion (in solve menu) to make sure the algorithm does its job well. Just after these steps, one can setup the BCs and run the program. one another point is to take Dt as small as possible. Also, as I have tested it myself, if there is not relative motion in the solid walls, e.g. deforming body or boundaries, applying the UDF as inlet BC is preffered.
Dynamic mesh Virag Mishra FLUENT 0 October 1, 2007 07:02
Dynamic Mesh Lety FLUENT 1 January 17, 2006 01:58
dynamic mesh - structured or cooper mesh Manoj Kumar FLUENT 2 November 11, 2005 01:18
dynamic mesh and sliding mesh nasser FLUENT 0 November 1, 2005 02:37
Dynamic mesh Hongyan_Huang FLUENT 2 December 15, 2002 08:17
