Thruster simulation using Dynamic meshing
Old   September 30, 2019, 03:04
Default Thruster simulation using Dynamic meshing
Anjali Parashar
Anjali Parashar is on a distinguished road
Hello everyone
As a part of my project, I am required to calculate the drag forces on a propeller (thruster) under motion. I have been able to estimate the drag forces on the thruster using Ansys fluent under stationary conditions.
However, once the propeller is in action, it will experience thrust and rotation of blades. Under these conditions, I am required to recalculate the drag forces. Since I am running out of time, I have been told by my guide to use dynamic meshing on the lines of "an already available model of a propeller" to simulate the thrust and rotation of the thruster. Also, it has to be done without using UDF.
Please guide me about how to for the same. Any research papers describing the methodology, video links or suggestions would be extremely helpful. My confusion is precisely about how to describe the rotation of blades and the thruster force using Dynamic meshing. So any already available analysis would be helpful. So, the mathematical procedure to calculate the forces and rpm of blades is not that relevant and it can be different also.
I need help with understanding the procedure.
Thank You
Anjali Parashar is offline   Reply With Quote
drag forces, dynamic meshing, propeller thrust
[ANSYS Meshing] Total struggle with meshing and simulation impact. (Documented) pauleck ANSYS Meshing & Geometry 0 December 9, 2014 07:38
Dynamic mesh simulation (pimpleDyMFoam) problem sidlof OpenFOAM Running, Solving & CFD 6 April 12, 2013 11:24
Dynamic Meshing with Flow 3D M_Agni FLOW-3D 1 June 13, 2010 18:20
[GAMBIT] Dynamic Meshing of a combustion chamber donarundas ANSYS Meshing & Geometry 1 December 2, 2009 07:13
Issues with dynamic meshing sridhu88 FLUENT 1 June 11, 2009 16:46
