Pro/E Model Volume Split
Old   September 11, 2008, 11:38
Default Pro/E Model Volume Split
Stubody
I'm modelling an engine intake system in GAMBIT 2.3.16: Intake manifold Ports for all cylinders Cylinder 1 including 2 open intake valves
I've imported the geometry from a Pro/E .prt file, and have had success with Cooper meshing the ports, and hex core meshing the manifold, but to make life easier in the 'busy area', I'm trying to split the bottom of the cylinder from the valve area, and also the end of port, valve area.
The only trouble is, I've tried every trick I can think of for producing the splitting faces, but I always come up against:
'has edges not common with the volume' or 'can't operate on face c_face.x with associated non-real geometry'
I've tried using IGES to import, but I come up against these issues when trying to split off the ports, using the curves from the imported geometry to produce the splitting faces!
Any ideas out there?
Many thanks in advance!
Old   September 12, 2008, 00:35
Default Re: Pro/E Model Volume Split
mAx
splitting virtual volume is not so easy in comparison with real volume. But you can try this: *split edges *split face with vertices issued from edge splitting *create face with wireframe option (with edge produced from split faces) *split volume with face produced from the last operation
Old   September 12, 2008, 04:18
Stubody
Many thanks - I'll give that a go and let you know how it goes.
Thanks again!
Split Volume in Gambit Meenu FLUENT 5 May 2, 2011 22:26
Volume split -- Meshing Kantipudi FLUENT 0 July 27, 2008 12:18
split volume Kabo FLUENT 1 January 28, 2008 07:08
Problem with Volume split...! sushii FLUENT 0 October 22, 2007 04:00
Flow + split volume Mark FLUENT 3 March 18, 2003 10:09
