parallalizing GAMBIT
Old   September 21, 2008, 02:30
Default parallalizing GAMBIT
tamjid
HI FELLOWS, i am facing out of memory problem during ghambit 3d meshing. i have core 2 duo ,2.5 GB ram m/c.
can gambit be run paralla as fluent. or is there any other idea.
please share.
thank you.
Old   September 21, 2008, 17:35
Default Re: parallalizing GAMBIT
red lemon
Gambit does not run in parallel. Try using a 64 bit machine and breaking up the model into more sub volumes. Otherwise use 64bit TGrid instead.
Old   September 25, 2008, 03:59
tamjid
how do you use 64-bit TGrid? explain a little bit.
thank you.
Old   September 25, 2008, 07:45
Ganapathy
Gambit is available only as a 32 bit version. TGrid is available in two versions. 32 bit as well as 64 bit. You need to download a 64 bit version of TGrid from Fluentusers.com You also need a 64 bit machine.
Old   September 30, 2008, 10:49
tamjid
thanks
i will try.
Gambit geometry creation: loading data to gambit C Ariyaratne FLUENT 10 March 17, 2011 16:39
Export data from GAMBIT to GAMBIT Sanjay Jain FLUENT 1 April 3, 2008 00:44
How to Import Gambit 2.2.16 file to Gambit 2.0.0 solomon FLUENT 0 January 4, 2007 14:49
