October 24, 2008, 02:01 |
urgent pressure condition for axial flow fan
Hello i am working on an axial flow fan rotating(73.68 rad/sec) inside a long casing of approx. 3 m length fan is installed at around 1.5 m inside casing.casing openings are at atmospheric pressure.i am doing analysis of only fan i am having static pressure of -11pa and total gauge pressure of 6pa at inlet of fan and static pressure of 12pa at outlet of fan.but results are not matching with the experimental results did i given correct boundary conditions? below is an idea of set up
casing fan casing exit opening inlet outlet (atm pressure) (atm.pressure ) (-11pa) (12pa) computational domain only fan inlet &outlet. |
pressure boundary condition for inviscid flow | kharati | Main CFD Forum | 1 | November 19, 2007 07:41 |
pressure boundary condition for inviscid flow | kharati | Main CFD Forum | 5 | November 12, 2007 02:27 |
Axial Fan flow Meshing | sidd | Siemens | 3 | April 20, 2007 03:32 |
Flow measurement around intake valve pressure condition problem | fedegavo | OpenFOAM Running, Solving & CFD | 1 | January 20, 2006 13:06 |
axial compressor data,urgent!! | blue | FLUENT | 0 | March 6, 2002 22:16 |
