UDF- assigning viscocity with respect to position
Old   October 23, 2008, 14:02
Default UDF- assigning viscocity with respect to position
Nikhil Dani
Dear all,
I am a final year student at IIT Madras. I am trying to model a single phase flow through an annular region. The specifications of the tube are- OD- 12mm, ID-6.6mm (xz plane), y=0 to 12mm. I wish to assign the viscocity of my fluid as mu=100 for certain nodes, and mu=0.1 otherwise.
This is the udf code I wrote.
#include "udf.h"
DEFINE_PROPERTY(visc,c,d)
real mu;
Thread *t;
real x[ND_ND];
C_CENTROID(x,c,t);
if(sqrt((pow(x[0]-0.0052,2.)+pow(x[1]-0.050,2.)+pow(x[2]-0,2.)))<0.002)
mu= 100.0;
else
mu=0.1;
return mu;
This code gives me an error.
Error: FLUENT received fatal signal (ACCESS_VIOLATION) 1. Note exact events leading to error.
2. Save case/data under new name.
3. Exit program and restart to continue.
4. Report error to your distributor.
Error Object: ()
Even if I use the same code as above, and give the command :
mu= 0.1;
else
mu=0.1;
I again get the same error. Which means that the error is not in assigning viscocity with position, but in the if clause I have used.
I would be most grateful for the help I could recieve.
Regards.
Old   October 23, 2008, 21:15
Default Re: UDF- assigning viscocity with respect to posit
CDE
try this:
#include "udf.h"
DEFINE_PROPERTY(visc,c,t)
real mu;
real x[ND_ND];
C_CENTROID(x,c,t);
mu= 100.0;
else
mu=0.1;
return mu;
Old   October 24, 2008, 10:07
Nikhil Dani
Thanks a ton!! It worked
Artificial viscocity jj Main CFD Forum 25 October 21, 2006 14:40
do it necessary to give viscocity expression? joseph CFX 1 May 6, 2006 09:56
tracking data with respect to time tucker FLUENT 2 December 20, 2005 08:39
Variable input with respect to time Prafull Gandhi CFX 2 September 4, 2005 08:36
How to set a boundary condition as a function respect to time chnrdu OpenFOAM Running, Solving & CFD 2 June 17, 2005 04:18
