rotating cylinder using sliding mesh
Like Tree1Likes
  • 1 Post By CDE
Old   November 9, 2008, 04:53
Default rotating cylinder using sliding mesh
Tim Daly
Hello. I am attempting to simulate the lift on a spinning cylinder using sliding mesh techniques. I create a first circular face for the cylinder, then a second circular face just slightly larger for interfaces and third circular face for a control area. I subtract the first face from the second face so that the cylinder is treated as a wall, and then subtract but retain the second cylinder from the third cylinder so that i can be left with two edges for interfaces. However when i do this the cylinder inside is created as a face again and two circular edges where the cylinder wall is meant to be are created. And i have tried a number of different ways of trying to alleviate this problem and get the cylinder moving in fluent, but even by applying a moving mesh to the fluid between the cylinder and interfaces the cylinder will not spin. Can anyone give any help on this. Thanks.
Old   November 9, 2008, 23:02
Default Re: rotating cylinder using sliding mesh
CDE
Why not mesh it like a stationary problem. Then in Fluent prescibe a moving wall with the axis of rotation being the cylinder axis. Doing it that way, there is no need for moving mesh or interfaces.
rshbhb likes this.
Rotating cylinder raul FLUENT 3 February 1, 2015 05:48
Rotating Cylinder IGE Jason Mc Beth FLUENT 0 January 23, 2008 07:02
Rotating Cylinder Nick Siemens 1 June 21, 2006 06:42
Rotating cylinder Johnny Main CFD Forum 5 December 7, 2004 09:55
2-D rotating cylinder Ossi Siemens 1 March 25, 2002 14:34
