Solidification problem: viscosity ratio limited
Old   December 11, 2008, 13:08
Default Solidification problem: viscosity ratio limited
Deepak
hi, I am modeling a continuous casting problem using solidification model in FLUENT. The case is 2d,unsteady and the domain is a rectangle with solid being pulled out of the domain. when i start iterating, after many time steps i get the message turbulent viscosity ratio limited in xxx cells. They tend to get limited in the cells near the area of interest, the solidification front. Also the appear only on the solid side of the front!. I m confused, do they have any meaning on the solid side? Also after many time steps they tend to distort the solidification front.
I have tried many methods that i found in this forum, i specified the boundary conditions turbulent parameters according to the eqn I=0.16*Re^(-0.125). Also i specified the initial values of k and epsilon according to the eqns k= 1.5*(UI)^2 and epsilon = (cmu^0.75*k^1.5)/l but it didn make any difference.
I also tried solving the laminar case first, then based on that i solved for the turbulence quantities and then switched on the momentum and energy eqns. still it didn work
can anyone tell me how i should deal with this problem?
any help will be greatly appreciated
turbulent viscosity limited to viscosity ratio of Hua FLUENT 7 September 27, 2019 06:42
turbulent viscosity limited to viscosity ratio... frank FLUENT 19 December 15, 2015 22:54
Turbulent viscosity Limited to viscosity ratio Adrian FLUENT 12 September 21, 2011 04:22
Turbulent viscosity limited to viscosity ratio... Cyril FLUENT 8 February 7, 2006 20:34
Problem of Turbulent Viscosity Ratio Limited David Yang FLUENT 3 June 3, 2002 06:13
