How to set up more than 270 planes in Fluent? |
December 9, 2008, 08:50 |
Hallo,
for analysing purposes, I need to create more than 270 bounded planes in the post processing (Surface -> Plane...). Since I do not want to spend about a week for typing the coordinates I am looking for an alternate, faster way. I have all coordinates for the planes in an Excel-file. So, it would be best, if I could just write a code and copy&paste the coordinates. I thought, that I could maybe modify the case/data file of my simulation and insert the planes there. However, I was not able to find the passage, where the planes are defined. Does anyone has an idea how to accelerate the creation of the planes? Good bye, Julian |
December 10, 2008, 06:11 |
Re: How to set up more than 270 planes in Fluent?
So I found a solution.
Using an Excel macro I created a journal file for Fluent containing all the coordinates. Now, Fluent does all the work for me, automatically... Topic Closed |
July 16, 2010, 12:29 |
Yarzar
Could you tell me exactly how the journal file works ? I am in a similar situation where I need to input over 200 surface points instead of surface planes. Thank you very much. |
January 5, 2011, 00:04 |
Hi all
what in this post is very helpful. would you kindly give explanation how dose this work with lines and planes? |
mixing planes | sulilatu | FLUENT | 0 | December 5, 2006 03:34 |
Creating Planes | Steve | FLUENT | 1 | April 6, 2004 14:43 |
Creating complex planes | Steve | FLUENT | 3 | April 6, 2004 12:55 |
Mixing planes | ramesh | FLUENT | 0 | July 30, 2002 02:33 |
Defining cutting planes | Daniela | FLUENT | 3 | December 19, 2000 08:13 |
