heat generating body inside fluid volume
Old   December 14, 2008, 13:48
Default heat generating body inside fluid volume
NITUL KALITA
I have a fluid volume. Inside it, I would like to place a solid volume as obstacle. Can I use solid as a heat generating body. All faces of Solid in the fluid volume after substraction will be defined as "walls".
thank you on advance.
Solid inside fluid volume JP FLUENT 5 December 5, 2008 12:51
How to create a fluid volume inside a solid volume sanin FLUENT 4 November 13, 2008 15:17
generating free mesh in the volume zaeem FLUENT 0 July 26, 2007 02:56
Inside, Outside or on the boundary of a Body? AFP Main CFD Forum 2 January 25, 2004 19:43
Heat transfer to fluid and pipe body Chris FLUENT 1 December 28, 2002 02:09
