Question about Dynamic Mesh
Old   December 23, 2008, 02:44
Default Question about Dynamic Mesh
Kosum
I'm working on dynamic mesh to analys a moving hydrofoil (flaping wing propulsion)and i decide to make 2 face
inner grid : contain hydrofoil profile wall. this
entire face will deform within outer grid
by equation i write in .c file. it's circle
with 10 cord diameter outer grid : this face will be stationary and have
to remeshing every time step
now i wonder that is this solution is right ? i mean IF this mean i'm moving the foil AND fluid around it (fluid have velocity from deforming grid) or this mean i still moving the foil alone ? i want to analyse a flow around hydrofoil , can i still use gambit this way
thank you
Old   December 24, 2008, 21:31
Default Re: Question about Dynamic Mesh
zhaowg
For dynamic mesh, you can establish it using gambit,like normal mesh; the moving is defined in the Sover,such as Fluent. So ,the most important thing you must do is in Fluent.
Old   December 25, 2008, 05:57
Kosum
hm...i see, thank you but it's fluent still need a appropriate mshing, though
Old   December 25, 2008, 10:00
zhaowg
Sure, especially to dynamic mesh.
A question about dynamic overset grids JXIA Main CFD Forum 4 January 10, 2008 03:50
question about dynamic meshes zhhwoo FLUENT 0 August 2, 2006 22:36
dynamic mesh - structured or cooper mesh Manoj Kumar FLUENT 2 November 11, 2005 01:18
A Question on the Dynamic procedure in LES dragon Main CFD Forum 1 April 28, 2005 15:11
A question about the dynamic mesh UDF Tango FLUENT 1 November 27, 2003 02:56
