Are there more FLUENT Turbulence Models?
Old   December 25, 2008, 23:00
Default Are there more FLUENT Turbulence Models?
Travis
I'm wondering if anyone has implemented additional user-defined turbulence models in FLUENT? I'm specifically interested in finding (or possibly writing) a curvature-corrected Spalart-Allmaras model. I'd really appreciate everyone's two cents on user-defined turbulence models, and if anyone's willing to share one they've written, it would help me get started! Thanks
PS: I posted this once before, but didn't get any responses despite 40+ hits. I was hoping I might get better luck the second time around.
Old   December 26, 2008, 14:25
Default Re: Are there more FLUENT Turbulence Models?
bubua
try to find example in user guide udf
Old   December 26, 2008, 20:45
Travis
I did... thanks for the thought but that was the first place I looked.
Old   December 30, 2008, 01:45
zongtwi
Hi, I'm no expert at turbulence modelling, even worse at using UDF to modify them. But you may want to consider changing/modifying the values of the constants of the SA model before going into using UDF. If you look up the documentation, you can see where the constants are being used. You may be able to modify any of these constants to give you the effects of your modified model, without having to write a UDF (which can get nasty!!)
If you really need to use a UDF, you can create your own Turbulent Viscosity equation using the Define_Turbulent_Viscosity macro. If you just want to modify the production and dissipation values, you can use the Define_Source macro.
Hope that helps.
Additional turbulence models for FLUENT Travis FLUENT 0 December 19, 2008 11:58
LRN-ke turbulence model(other than Fluent 6 models Wael FLUENT 0 October 17, 2005 04:03
Low-Re turbulence models in Fluent 6.0 Iason Hatzitheodorou FLUENT 3 July 8, 2004 11:48
turbulence models rafal Main CFD Forum 3 April 26, 2004 11:27
LRN turbulence models in Fluent Luo Shengping FLUENT 6 December 22, 2000 09:59
