Text Commands For Iso Surfaces
Old   January 7, 2009, 18:33
Default Text Commands For Iso Surfaces
Justin
I need to create iso-surfaces in specific zones based on grid coordinates. I would normally do this under the gui, but my file is to big so I have to do it as a batch job. The manual gives me the following command: surface/iso-surface I don't know how structure the rest of the command to specify the zone and position.
If anyone can post a few lines of a journal file in which iso surfaces are created it would be amazingly helpful.
I need to do about 400 of these, so the plan is to generate the commands using Matlab.
Old   January 8, 2009, 04:49
Default Re: Text Commands For Iso Surfaces
max
Hi Justin
the following text command will create an isosurface named x0 of constant x-coordinate 0 within a given fluid zone with zone id "ID". "ID" is an integer which you can get from the boundary condition panel.
surface iso-surface x-coordinate x0 () ID () 0 () q
cheers Max
UDF and text commands David FLUENT 3 June 26, 2022 23:10
Creating iso-surface with text commands Cyril FLUENT 1 August 23, 2006 11:38
text commands and turbulence models SAM FLUENT 0 October 18, 2004 17:18
input only by text commands Peter Kolb FLUENT 1 April 17, 2001 07:02
Patching with Text Menu Commands Greg Perkins FLUENT 2 February 13, 2001 03:16
