January 15, 2009, 14:29 |
Importing files to GAMBIT
I have an AUTOCAD file, and I want to work with it in GAMBIT. I`m having big problems with the importation. What`s the best way to import files to GAMBIT???????
January 16, 2009, 00:23 |
Re: Importing files to GAMBIT
step file is ok (there are other good format)
in your case, I assume you only have the possiblity to export *.dwg in *.iges You may import iges file into gambit, but the quality shouldn t be as good as the other. Clean Up options will be helpfull |
January 16, 2009, 12:29 |
Hola Carlos,
hablas español?, si es asi te puedo dar bueno informacion para solucionar tu problema, ya que me paso algo similar y pude arreglarlo. Saludos |
Importing IGES files into GAMBIT and meshing | kartik | FLUENT | 3 | September 23, 2008 00:12 |
Importing Gambit files into CFX | CF | CFX | 8 | September 25, 2006 02:14 |
Importing autocad files into GAMBIT | Shanti | FLUENT | 3 | June 6, 2006 06:07 |
Importing files from Pro/E to Gambit | Kiran | FLUENT | 3 | October 5, 2004 16:00 |
importing gambit files into cfx | sivakumar | FLUENT | 3 | October 15, 2001 10:09 |
