How can i use Tpoly to obtain Polyhedra?
Old   January 19, 2009, 17:45
Default How can i use Tpoly to obtain Polyhedra?
Murat
Dear all,
I want to use tpoly process. But i do not know how to use it and from where? There is a commond like 'utility tpoly input_filename output_filename' but, where will i write this command to? i tried to write it on fluent, it did not work. Can you explain please, how i can use this command?
Old   January 20, 2009, 13:14
Default Re: How can i use Tpoly to obtain Polyhedra?
Allan Walsh
If you are using Windows, well DOS, go to the command line and type it in "tpoly input output". Of course, all of the files will have to be in the path.
Why Differences between tetrahedra polyhedra and prism mesh pipe flow computation with sonicLiquidFoam chnrdu OpenFOAM Running, Solving & CFD 5 May 7, 2018 03:23
Problems on Tetrahedra to Polyhedra using polyDualMesh on concave surface object chnrdu OpenFOAM Pre-Processing 2 July 18, 2009 12:58
How to obtain forces Karimu FLUENT 2 August 22, 2005 17:26
StarCCM+ polyhedra cell generation new-user Siemens 9 October 14, 2004 03:45
How to obtain.... Sharad Dugad FLUENT 6 February 13, 2002 12:14
