Help with Mesh motion preview
Old   January 20, 2009, 15:37
Default Help with Mesh motion preview
Mustafa Ayad
Hi all i have this error when i do Mesh motion preview of the angular velosity of gears in ger pump any one can help me.
Done.
Updating mesh to time 1.00000e-04 (step = 00001)... This is Clockwise Gear
CG_Omega for clock_wise: 0, 0, -210
CG Position for clock_wise: 7.06373e-306, 1.77272e-295, -2.68156e+154
CG Orientation for clock_wise: 7.06373e-306, 1.77272e-295, -2.68156e+154
This is Anti Clockwise Gear
CG_Omega for antic1ock_wise:0, 0, 210
CG Position for antic1ock_wise:7.06373e-306, 1.77272e-295, -2.68156e+154
CG Orientation for antic10ck_wise:7.06373e-306, 1.77272e-295, -2.68156e+154
WARNING: non-positive volumes exist.
Dynamic Mesh Statistics: Minimum Volume =-1.56742e-004 Maximum Volume =6.50694e-004 Warning: negative cell volume detected! Error: Update dynamic mesh failed. Negative cell volume detected. Error Object: ()
Old   January 20, 2009, 20:33
Default Re: Help with Mesh motion preview
zongtwi
Does this only occur when you want to preview your mesh motion? What about when you run the simulation, does the same error occurs?
Obviously, I don't really know how your case is, but non-positive volume usually exists because your moving domain is connected to the stationary domain. You need to explicitly disconnect the different zones inside GAMBIT.
Hope that helps.
Old   January 20, 2009, 22:40
Uday
Hi
If your are getting an error for negative volumes the mesh some where might be collapsing i.e. forming degenrated cells.
1)The C.G. defination might be wrong you can check the motion of your gears with zone motion prior to mesh motion preview which will give you the exact motion set by your definations.
2)And if all the above things are rght try to reduce the time step.
3)Let me knw r u running the case in 64 bit machine
Uday
regards
[blockMesh] Preview mesh in Paraview gareth__it_power OpenFOAM Meshing & Mesh Conversion 8 June 4, 2011 12:13
mesh preview mode lee Siemens 2 June 16, 2007 05:10
Cannot preview the dynamic mesh sam FLUENT 4 May 26, 2005 06:58
Cannot preview mesh motion! dvinh FLUENT 0 August 17, 2004 23:44
about preview mesh motion lingo FLUENT 1 July 8, 2004 12:13
