Problem running Fluent on amd64
Like Tree1Likes
  • 1 Post By Autumn
Old   February 4, 2009, 06:51
Default Problem running Fluent on amd64
Manfred
Hi, I've got a problem running Fluent on Ubuntu 8.10 x64. When I start the program I receive the following message error /bin/fluent -r6.3.26 /bin/fluent: 4677: domainname: not found /cortex/lnamd64/cortex.3.7.3 -f fluent (fluent " -r6.3.26 -path/home/manf/Fluent/Fluent.Inc") /cortex/lnamd64/cortex.3.7.3: error while loading shared libraries: libstdc++.so.5: wrong ELF class: ELFCLASS32
I am a newby in the Linux world, so I don't know what to do, please help.
Old   February 5, 2009, 06:00
Default Re: Problem running Fluent on amd64
Manfred
This is the correct form of the message
I've omitted the path of Fluent Folder in order to simplify the post
Old   February 8, 2009, 15:14
Martin Skov Skjøth-Rasmussen
I have Fluent running on Ubuntu X_64, and experienced the same problems. What you need to do is to install all missing libraries:libstdc++.so.5 for one... In a terminal window: sudo apt-get install libstdc++5 sudo aptitude install libmotif3 sudo aptitude install libxaw7 /Martin
Old   February 14, 2009, 06:01
Manfred
Thank you Martin, seems to work
Old   April 20, 2009, 02:59
Default problem ruunig fluent on ubuntu 8.1 (64 bit)
Reza Khane Mir5
Mir5 is on a distinguished road
I have problem in installing fluent 6.3 on ubuntu 8.1
I have installed the fluent software and then installed following packages:
So i run the fluent in 2d or 3d version
But i have the following error :
/Fluent.Inc/license/lnamd64/fluentlm-helper91: no such file
No error handler available
Anybody Can Help?
Mir5 is offline   Reply With Quote
Old   July 31, 2009, 07:29
RPereira's Avatar
Ricardo Pereira
RPereira is on a distinguished road
I've the same problem as Mir5 for FLUENT...
And for Gambit I've this error:
LANG en_US.UTF-8 changed temporarily to en_US for gambit use.
Starting /Fluent.Inc/gambit2.4.6/lnamd64/gambit ...
*** can't exec /Fluent.Inc/license/lnamd64/fluentlm-helper90: No such file or directory
FATAL ERROR: Could not obtain valid license authorization.
Total of -0.65 cpu second(s), 158608 maximum memory.
Received exception: SIGSEGV (segmentation violation)
Anybody can help please?
RPereira is offline   Reply With Quote
Old   September 9, 2009, 09:08
Jacques is on a distinguished road
Anybody could solve the problem?
Thanks for your help!
Jacques is offline   Reply With Quote
Old   November 23, 2009, 12:56
Autumn Fjeld
Autumn is on a distinguished road
I have had the same problems and errors with 'fluentlm-helper90' and 'fluentlm-helper91' while trying to get Fluent 6.3 and Gambit 2.4 running on a 64 bit machine running Fedora 12.
My friend has just found the reason for this! It is because something in the 64-bit version of Fluent is still linked to 32-bit libraries. In Fedora 12 we had to install glibc.i686 -- the 32 bit version in addition to the 64-bit glibc that comes default with Fedora. This link has a bit more specific info of what we had to install http://osdir.com/ml/fedora-test-list.../msg00944.html.
Mojtaba.a likes this.
Autumn is offline   Reply With Quote
Old   April 19, 2010, 04:42
Quentin de Radiguès
quentin.deradigues is on a distinguished road
I've got the same problem as Manfred. When I do:
I have an error: impossible to find package libstdc++5. It is possibly no longer available. Does anyone have an idea?
Thank you!
quentin.deradigues is offline   Reply With Quote
Old   November 20, 2010, 18:19
erdem
livera is on a distinguished road
I installed 64-bit version of FLUENT and I am using MINT 10. When I run the program I faced with the following problem.
"/Fluent.Inc/license/lnamd64/fluentlm-helper91: no such file or directory
No error handler available"
Is there anybody solves this problem.
Thanks
livera is offline   Reply With Quote
Old   March 23, 2013, 06:47
Mojtaba.a's Avatar
Mojtaba Amiraslanpour
Mojtaba.a is on a distinguished road
Send a message via Skype™ to Mojtaba.a
Thanks
I am using Ubuntu 12.10, installing ia32-libs did the trick,
sudo apt-get install ia32-libs
Good luck
Mojtaba.a is offline   Reply With Quote
[Commercial meshers] Problem in running mesh imported from fluent to foam vishal OpenFOAM Meshing & Mesh Conversion 2 February 6, 2009 10:05
CFX running problem Michael CFX 4 January 26, 2007 07:40
PVM running of FLUENT Joe Yan FLUENT 0 February 27, 2006 03:48
Running Fluent Manish FLUENT 2 December 4, 2004 20:18
Fluent for AMD64 confirmed J.P. FLUENT 1 October 8, 2003 17:42
