Inlet turbulent boundary condition: external flows
Like Tree1Likes
  • 1 Post By Alagesanj
Old   February 6, 2009, 11:03
Default Inlet turbulent boundary condition: external flows
ROOZBEH
Dear FLUENT user;
I want to simulate an external turbulent flow. To set the turbulence boundary conditions, there are some formulations in the software documentations, but unfortunately they are just for internal flows (duct flow).
How can I calculate the in-flow K and Epsilon for an external flow, for example the flow around a flat plate.
best regards, Roozbeh
Old   February 7, 2009, 20:49
Default Re: Inlet turbulent boundary condition: external f
Alagesanj
Hi Roozbeh,
"For external flows the value of turbulent intensity at the freestream can be as low as 0.05% depending on the flow characteristics. You may have a good estimate of the turbulence intensity at the freestream boundary from experimentally measured data". The quote is taken from this link. http://support.esi-cfd.com/esi-users/turb_parameters/ You can follow this link and read through it. This document is for CFD ACE+ but generally applicable to all codes.
Cheers,
tareqkh likes this.
Old   February 8, 2009, 07:02
ROOZBEH
Hi;
Thank you so much. That was very interesting and useful.
Roozbeh
Old   August 28, 2015, 15:34
Default Turbulent intensity and viscosity ratio for flow over turbine
TKP
TKP
TKP is on a distinguished road
I am unable to find way to give Turbulent intensity and viscosity ratio for flow over turbine (external flow). Kindly help
TKP is offline   Reply With Quote
External,incompressible flow boundary condition? John FLUENT 2 August 19, 2011 00:42
Inlet turbulent boundary condition, external flows ROOZBEH Main CFD Forum 1 February 6, 2009 12:37
Boundary conditions for external flows ryan_m OpenFOAM Running, Solving & CFD 3 May 19, 2008 09:49
External Aero-boundary condition. Guest FLUENT 0 April 14, 2006 19:31
External,incompressible flow boundary condition? John Main CFD Forum 0 October 1, 2003 00:00
