Mixing plane for centrifugal compressor
Old   March 24, 2011, 17:27
Default Mixing plane for centrifugal compressor
Claudio
Mitpostdoc is on a distinguished road
Hello there,
I am running a simulation of a centrifugal compressor in fluent. I am simulating a single passage using the mixing planes.
Unfortunately, right after the impeller there are some labyrinth seal passages. In order to keep them in the "stationary" reference frame I should place the mixing plane right at the trailing edge of the impeller blade.
I could not find any reference in the manual and the tutorials. Is there any problem in placing the mixing plane just at the trailing edge of a compressor blade? Most of the test cases I saw have a small gap between the blade and the mixing plane. Is that important.
Thanks
Mitpostdoc is offline   Reply With Quote
mixing plane model: too much backflow and does not converge sbhi FLUENT 1 December 4, 2014 00:31
Meshing a Mixing Plane in ICEM Will Anderson ANSYS Meshing & Geometry 2 November 9, 2010 09:16
Meshing a Mixing Plane using ICEM Will Anderson FLUENT 0 November 6, 2010 17:08
Mixing Plane Lee FLUENT 0 August 8, 2003 22:36
Mixing plane geometry definition Hbet FLUENT 0 January 18, 2002 07:16
